My hd5 project |
Wawill
Joined: 13 Aug 2017 Location: Western Austral Points: 15 |
Topic: My hd5 projectPosted: 13 Aug 2017 at 10:35am |
_IMG_000000_000000.jpg hi guy's new to the forum just picked up this 1952 model I'm in Western Australia hope to slowly get it up to scratch but has a broken drive axle and clutch seams to slip if not holding leaver back anyway should keep me busy for a while
Wawill
Posted: 13 Aug 2017 at 10:59am |
Here is a few more pictures of it has the letournea power control winch on the back
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42276 |
Posted: 13 Aug 2017 at 11:05am |
master clutch is adjustable through plate on right side of bell housing- need a 9/16 wrench and a pry-bar to move adjusting ring to tighten overcenter clutch tension
depending of if dozer or loader will set the challenge for replacing broken axle . if you search back there is a lot of info on HD5 on this site
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34642 |
Posted: 13 Aug 2017 at 11:36am |
Wawill
Posted: 13 Aug 2017 at 5:48pm |
Cheers coke I'm hoping that's all I need to do and that the clutch is not worn out I was amazed the old dozer had been sitting for about 10 years without running and she fired right up pretty impressive those little gm motors
donoman
Joined: 18 Feb 2015 Location: New Zealand Points: 117 |
Posted: 14 Aug 2017 at 12:57am |
Well worth restoring. especially with the Le Tourneau blade gear. good luck
donoman
Posted: 14 Aug 2017 at 12:58am |
Plenty of final drive parts in NZ
Wawill
Posted: 14 Aug 2017 at 7:35am |
I haven't seen any other hd5 with the le tourneau blades on them are they very common and does anybody have any hints and tips for operating and maintaining it
Wawill
Posted: 28 Aug 2017 at 4:33am |
Had a look at the steering breaks today to see why the rhs break wasn't working and the culprit was rust
JC-WI
Posted: 28 Aug 2017 at 10:00am |
A little JB Weld might fix that...LOL
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35740 |
Posted: 28 Aug 2017 at 11:05am |
Someone once thought they would develop a rust welder, have not seen the contraption yet but may be accessible in AU?
LeonR2013
Posted: 28 Aug 2017 at 8:11pm |
Good looking under carriage. Man what a set of grousers. They'll either get you out or dig a hole deep enough that all you have to do is push a layer of dirt over the top to bury it. LOL
Wawill
Posted: 28 Aug 2017 at 10:22pm |
Just wondering if anyone reckons I could get a break band of another dozer and adapt it to fit the Allis chalmers the price I got told for one wasn't cheep
JC-WI
Posted: 28 Aug 2017 at 11:02pm |
The band was made by somebody to start with... just find another band and weld your components on...
Wawill
Posted: 28 Aug 2017 at 11:21pm |
That's what I'm thinking if it's made by man can be fixed by man
