Hour Meter Install |
Brian G. NY
Orange Level Joined: 12 Sep 2009 Location: 12194 Points: 2244 |
Posted: 23 Jul 2010 at 12:43pm |
I want to install an hourmeter on my WD-45.
I would like to go the extra step and wire it so that it reads only when the engine is running rather than whenever the ignition is turned on.
I know they can be wired thru an oil pressure switch to accomplish this.
Would a common low oil cutoff switch from a portable generator or such work for this?
Does the WD-45 provide enuf pressure to close the points on one of those switches?
Should I just hook it into the ignition and forget it? LOL
Thanks for any help.
kip in cny
Orange Level Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
I would just wire it so when the key is on alot less work.
160 CA 920diesel 5020 HD-3
M Diesel
Silver Level Joined: 26 Feb 2010 Location: Las Vegas Points: 128 |
A cutoff should work unless the idle pressure is down there a ways. I use a fuel pump safety switch. Those can be had down to 5 psi or so with a regular npt fitting. Not hard to do.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41758 |
Go the extra and put a pressure switch in, you will not regret it as you will have accurate reading on hours.
Stan R
Orange Level Access Joined: 03 Dec 2009 Location: MA Points: 963 |
What would you expect the time difference be from Key on ONLY vs KEY on/ Engine On? I would suspect the difference would be insignificant and not justifiable to go beyond connecting it thru the key switch, so why bother.
Chris/CT
Orange Level Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
I have a AC [ what I think is an AC part] Hour meter if interested. I do not know if it is functional, e-bay purchase years ago, have no use for it.
Jacob (WI,ND)
Orange Level Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1247 |
Here is another post about this, might help
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
firebrick43
Orange Level Joined: 10 Dec 2009 Location: Warren County Points: 592 |
Google Tiny tach. They have some good hour meters that record only when the engine is firing. They have one wire that attaches to ground and one sense wire that wraps around a spark plug wire. This wire tell the hour meter that the engine is running and measures rpm. They are self powered by a battery and they can be mounted out of site with double sided tape or epoxy glue to not affect the original look or dash, or mounted in the open. They also give you an rpm read out to adjust your governor and idle speed. One model even has service reminders.
