diesel hydrostatic wc
mintenfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Topic: diesel hydrostatic wc
    Posted: 26 Jul 2017 at 9:33pm
so my latest and greatest idea is to fa up an engine driven hydraulic pump and put a hydraulic motor to drive the rear axle. my question is, would i be better to drive the reaer axle directly or through the transmision with different "ranges"
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 9:46pm
Hydraulic and hydrostatic drive are not the same thing...just sayin
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 9:56pm
well the goal is a hydraulic driven tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 10:12pm
As long as you just want fun and unique you'll be fine.Trying to do serious work will not be so rewarding.Ineffecient is the word.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 10:15pm
Could you belt drive it from the belt pulley?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 10:20pm
Trying to do serious work will not be so rewarding. Ineffecient is the word.
IH tried that, didn't they?
Seems it would be good for pulling a combine or doing haying work, but not much else.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 10:22pm
If it has a pto, why not put a hydraulic motor on that and run it from there?
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 11:30pm
Neighbors bought 2 of those little IH gas hydro tractors.Didn't have them long before trading for gear diesels.Said they were GAS HOGS!!!.Yup,hydrostatic is good for for variable speed and reversing but not hard field work. Pumping oil creates lotsa heat which is wasted energy.
Edited by SteveM C/IL - 26 Jul 2017 at 11:33pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 7:22am
Most larger tractors with hydrostatic drive still use the transmission.
You need a variable displacement pup to take advantage of the hydraulic drive. Use a second pump on the back of the variable pump for the PTO
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2017 at 8:30am
Friend of mine had a 656 gas hydro. It was a great tractor on a disc mower but as previously stated you need a fuel truck in the field.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
