1954 A/C Tractor
PKW-K1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PKW-K1 Quote  Post ReplyReply Direct Link To This Post Topic: 1954 A/C Tractor
    Posted: 22 Jul 2010 at 3:44pm
Gentlemen, I have in my possession a 1954 A/C Two-Row Planter Tractor, and what I need to know is/are there folks out there searching for this model Tractor???? I can supply images {pictures} upon request.
PKW-K1
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 4:07pm
Pictures would be best, as it could be a few different models.  Attach the picture to a post on here.  I'm sure that no matter what model it is, someone would probably be interested - depending on price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PKW-K1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 4:57pm
How does one upload images to this website?????
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 5:46pm
you can email them to me and I will post them
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PKW-K1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 6:22pm
Gentlemen ~ ~ Let's see if this link will work for images of the 1954 Tractor
http://img121.imageshack.us/g/actractor4.jpg/
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 6:33pm
Uploaded with ImageShack.us
What you have here is a single front wheel CA. Somewhat desirable, but don't expect to try selling this for a boatload of money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 6:34pm
Another View
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 7:10pm
I sent you a PM. I might be interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PKW-K1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 7:39pm
Gentlemen~ ~   I also have a Continental Auger ~ ~ ~ use link below to view ~ ~
http://img6.imageshack.us/g/gearboxn.jpg/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 7:44pm
Looks like you have a plow and other items with it.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PKW-K1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 7:45pm
Thanks for up-loading those two images, I was trying to send you a PM, but was told that you had reached your limit of in-bound messages. I wish to as you a question as per your last reply~~~~
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 8:02pm
I'll fix my mail box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 8:07pm
Sure is a post 1952 model with snap couple lift latches, traction booster gauge and the later style air cleaner. I bet she'd make a good belly mower tractor with that single front wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 8:27pm
I own a late 52 with that style aircleaner. Is that seat spring in a strange location? I know there are 2 positions for the spring but that doesn't seem like one of them.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2010 at 9:10pm
Single Front Wheel CA.
As you can see, this is a tractor people are interested in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2010 at 9:13am
wkpoor, I hadn't noticed the seat sprig. It looks like it was set up for a light weight person.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PKW-K1 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2010 at 6:23pm
You are correct. My Grandfather, the previous owner, plowed and prepared his fields to plant corn, then harvested this corn with towed a single row corn-picker, then ran a Hammer Mill to grind this corn and then mixed this {milled} corn with salt and linseed meal to make a feed. There were three other pieces of equipment He used with this tractor, a Continental Fence-post-hole Auger, a Servis mower and a "V" bottom fertilizer spreader. So "YES" to your statement, You can use this tractor for several different functions......PKW-K1
