AC 616-620 ? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10920 |
Topic: AC 616-620 ?Posted: 20 Jul 2017 at 5:19pm |
Are the flywheels on the CCKA and CCKB used on the 616-620 the same. I was wondering if they would work on either tractors charging system. Thanks Tracy
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1888 |
Posted: 21 Jul 2017 at 5:55am |
they are different and even with the ccka's there are differences. There are steel and aluminum flywheels out there
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4062 |
Posted: 21 Jul 2017 at 12:16pm |
charging systems are also differant and some cckb generator engines do not have a ring gear or starter they motor the gen to start it, i know this because we got one running for a guy about a month ago 6500 watt 1800 rpm in a motor home , real heavey gen for a motor home by todays standards
Tracy Martin TN
Posted: 22 Jul 2017 at 12:19am |
I was asking would a flywheel work with either charging system. I know one is a 15 amp and the other was a 20 amp. Is there a difference in the magnets? Thanks Tracy
Steve in NJ
Posted: 25 Jul 2017 at 7:53pm |
Stator is different. Not sure on the flywheels. Couple different kinds on these crazy Onans.
Tracy Martin TN
Posted: 25 Jul 2017 at 9:02pm |
Would the 20 amp stator, be too much for the 15 amp harness? Tracy
Steve in NJ
Posted: 27 Jul 2017 at 8:35am |
A 15 amp Stator is to much for a 15 amp harness! LOL! Those OEM harnesses are borderline to say the least. You could probably use the 20 amp stator I would think. Just change the fuse or circuit breaker to 20 amp. The engine compartment gets so hot in these particular model Tractors, the wiring takes a beating and gets BBQ'd.
Steve@B&B |
