WD-45 Oil flow
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Oil flow
    Posted: 15 Jul 2017 at 5:59pm
I'm just finishing a complete engine rebuild and would like to know the best way to get rid of the oil bypass.
Thanks & God Bless
Dennis
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 7:21pm
Do you mean plug  it off or replace it with a full flow system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 7:57pm
I would like 100% of the oil to be filtered.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 8:45pm
It's in the knowledge base. I'm using my cell phone right now so I can't link to it. It looks complicated. New oil pump and all.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 9:27pm
There's an article how to make the change in the knowledge base. Unfortunately photobucket took the pictures down. I'll have to upload them to the forum to make the article useful again.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 9:52pm
Just wondering what kind of use this tractor is expected to see?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2017 at 11:13pm
You'll be drilling and tapping existing oil passages.Better when it's apart but with regulated air blowing the right way for given drilling/tapping,I think it could be accomplished assembled. Doc said he did a WD in the tractor once.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 10:36am
The bypass system has functioned for nearly 70 years in that tractor so long as the filter makers didn't mess up by "modernizing" the filter to folded paper instead of stuffed full with fibers. Maybe it desired oil changes more often than the full flow system, but considering the changes in oil performance in that time period the modern detergent oil with anti corrosion additives works better than the oil did in the 1950s and before.
Gerald J.
Edited by Gerald J. - 16 Jul 2017 at 6:29pm
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 5:47pm
If you're just finishing the rebuild it's too late, unless you want to take it down to BARE block again. There is some drilling and tapping deep in the block and with cam and crank in there's no way you could get all the shavings out. You also need to find a late D17 oil pump and filter base/lines to make it work. It is definitely superior to bypass and worth the work.
Edited by Bill_MN - 16 Jul 2017 at 5:51pm
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 8:12am
Dennis the stock oil filter system will do just fine.  That engine as is will outlast us all.Thumbs Up
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 9:59am
Today's better oil and a good full flow oil filter will give you more time on an engine between overhauls. You might even be able to get by with fewer oil changes. The problem is the cost of the project will be greater than the return you'll get with extra engine life.
Edited by DougS - 17 Jul 2017 at 10:00am
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 12:40pm
The reason I asked what type of service the tractor is likely to see has been touched on by a couple of the other posts.  If it's going to go on tractor rides, parades and tractor shows a few times a year and then maybe rake hay a few times, then I doubt that you'll ever see any benefit to doing this conversion.  If it's going to be the main field power on your farm (unlikely I assume) then go for it.  If you just want to do it, go for it. Otherwise I'd just leave it the way it's been for the last 60+ years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 12:56pm
...it's simple,easy and inexpensive to change....why wouldn't ya?
