HD5G hydraulic pump |
DavidnTenIll
Bronze Level Access
Topic: HD5G hydraulic pumpPosted: 11 Jul 2017 at 5:30pm |
Am looking for a usable Vickers or Hydreco pump for Hd5g.
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35757 |
Posted: 11 Jul 2017 at 6:06pm |
I have the spare off my 7G if it is similar?
DavidnTenIll
Bronze Level Access
Posted: 11 Jul 2017 at 7:08pm |
I dont know about HD7. Numbers i have for pump is either a 2025G1B1 Hydreco or Vickers V300 28. Should be a tag on your pump. Thanks, David.
Posted: 11 Jul 2017 at 8:08pm |
Will dig it out tomorrow or Thursday as is in the barn and check.
Decided to check parts book, mine is a Tyrone, not Hydreco or Vickers Edited by DMiller - 11 Jul 2017 at 8:23pm |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42280 |
Posted: 11 Jul 2017 at 10:31pm |
The vickers is a vane pump and was used on the early units - the problem is finding the matching drive plate to fit crank pulley on that pump .
I have a spare pump but the internals are scored so questionable, in my HD5 pile . I did pick up a Hydreco about 2 years back at Hutch but have not looked at it since - its somewhere in my pile of spare things - one of these days projects .
Finding a 32 GPM pump @ 1800 RPM presents somewhat a problem |
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 12 Jul 2017 at 5:36am |
The hydraulic pump on my HD5B is much smaller than the pump on my HD6G.
Dave or Rob (800) 398 3448 wrights@adams.net had an hd5 pump last November when I bought parts from them. |
Dozer
Posted: 12 Jul 2017 at 5:39am |
Wrights also had the pump drive.
Coke-in-MN
Posted: 12 Jul 2017 at 8:38am |
oops the 5G used the 32 GPM pump - on a B with only blade lift needed GPM is a lot less
DavidnTenIll
Bronze Level Access
Posted: 13 Jul 2017 at 7:44pm |
Found a Prince Hydraulics 32 gpm pump on surpluscenter.com that I have decided to go with. Gear pump 2500 psi max. 32 gpm at 2000rpm for $389.00 will require some mount and coupling modifications. Appreciate the posts and info. Thank you all , David.
Dozer
Posted: 14 Jul 2017 at 5:13am |
Post pictures of your conversion.
Dozer
Posted: 14 Jul 2017 at 6:15am |
Are you considering a 1 3/8 six or 21 tooth PTO pump? The crankshaft drive would be easy. Please post the prince part number.
DavidnTenIll
Bronze Level Access
Posted: 15 Jul 2017 at 5:13am |
Prince part # SP25A63A9H2L is the number of pump were going to try. It will require fabricating/machining of pump mount bracket and a coupling modification. David.
Dozer
Posted: 15 Jul 2017 at 6:45am |
Your SP25A63A9H2L pump is aluminum with O Ring Boss fittings. Get short lengths of ORB pump fittings on one end so that you can make the hose conversion at a convenient place under the rock guard.
DavidnTenIll
Bronze Level Access
Posted: 15 Jul 2017 at 8:08am |
Yep. Planning orb to jic37° fittings. Trying to figure best way to put some filtration in hydraulic system. Quite polluted. Sucked out bottom of my left tank with a tube extension. Lot of sludge/dirt. No access to right tank other than return and crossover. I know they had a factory option for filters but not sure where they plumbed in. David.
Dozer
Posted: 15 Jul 2017 at 4:10pm |
I suggest a short hose on each port of the pump because the pump is aluminum. You have a good chance of damaging the threads on the pump when it is attached to long difficult to align hose. The hose attachments to the pump are difficult because of the rigidity of the hose and the near by 90 degree bends. I have done this on my HD6G's. I am thankful for the remote connection whenever I have to deal with the hydraulics.
Good luck Post pictures |
DavidnTenIll
Bronze Level Access
Posted: 17 Jul 2017 at 8:05am |
Thanks for the suggestions. Will keep in mind.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34645 |
Posted: 17 Jul 2017 at 9:20am |
Can cut a hand clean-out hole into tank near base and then make a new cover for it to bolt on, seen that done a few times. but requires drilling and tapping.
Coke-in-MN
Posted: 17 Jul 2017 at 9:33am |
Did you check under the valve body for access to right tank ?
DavidnTenIll
Bronze Level Access
Posted: 18 Jul 2017 at 6:02am |
Yep but it looks like you have to remove valve assembly as it looks like that's where valve returns oil to tank. Thought about cutting clean out access too. Oh well more to do.
Coke-in-MN
Posted: 26 Jul 2017 at 12:28am |
A screen filter on the intake as a filter of any other kind would restrict flow , and you could rinse the tanks through the top - yes the oil return is into right tank under valve body -
No good way to filter the return side - and high pressure filter is a real chore Flow pressure should be between 1200 and 1500 PSI - unsure if cylinder seals will stand much over that for extended time without heat buildup |
