138 CI engine |
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2032 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jun 2017 at 9:19am |
Found a 138 cu in power unit. What other Allis equipment used this engine?
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87576 |
The 138 was designed after the 125 ( B- C- CA) and was used in the D10-12 tractors. You can put the 138 in place of the older 125 ..... might be a tad underpowered for a D14, but would work.
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
138 engines were just used in the early non live PTO D-10/12 tractors besides power plants etc.
Thinking of putting it in a CA. The breather tube would need to be moved.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
One can put the 149 Piston/Sleeves in the 138 to make it a 149. If memory is right, the crank, cams, and heads are interchangeable. The 138 is 5-10 more HP than the 125. Don"t know what other mods are needed to drop the 138/149 into the CA; however, would expect some as the 138/149 were used in the next generation after the B/C/CA tractors (the D10/D12/D14/D15). Sounds like a fun project and should make the CA more lively.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Started the 138 today and it runs nice. Looks like the radiator will need a new hole on top and the valve cover will need a new hole in the center to work in a CA
Radiator hole......Boooooo
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34304 |
Can you just change valve covers?
Got a D14 engine parts/block head... and was wondering if its possible to drop the engine into an RC and build it to 40-50 hp? |
We put a complete 138 head on a D-14 149 engine.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5086 |
Lon:For the top radiator hose, just get the top hose fro a D10/12 tractor. No need to do anything for the radiator. Although you'll need to find a place to mount a temperature gauge.
JC: The 138/149 can use an overhaul kit that will bring it up to 155 and will have higher compression. That along with some cam work head porting and a larger carburetor will get you into the 40-50 HP range. However I have gotten a BE/CE block much larger than that and making about 75 HP.
What is different in a b and c engine from a ca other than gov spring.Restored a 49 b and put a ca carb on and had to file out holes to get it on .Cranks runs and pulls good but surges at high no load. Have adj gov rod. Seems to be a little rich.Wonder about intake and venture in carb.
Looks like a D14 upper hose will work if I trim it. I have not solved the valve cove issue yet. Had hoped that a B valve cover would work, but not the case. Looks like a new hole will be made in the valve cover. The temp gauge is another problem.
I cut the grass today with the CA and will do the engine change out tomorrow. Should be fun.
wbecker ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: STL Points: 837 |
I put a D14 149 engine in my lowered B for mowing. These are some of the things I needed to do. The 138 eng. should be all the same.
Had to use the B fan, and the B flywheel and clutch. The D14 manifold required moving the muffler hole a little bit. The B air filter will not fit with the D 14 manifold so I fabbed a new tube and used a K&N filter, and moved the hole in the hood. Made a instrument box mounted on the steering column for the temp and oil pres. Needed to drill out the holes in the radiator mount to the engine to 5/8". I made a patch to cover the B temp gauge hole and oil cap hole. I also added the fuel gauge mount from the D14 tank, of coarse not necessary. That's all I can remember, it all worked out well, have fun. Bill B |
Got the 138 in the tractor today. Have to work on a broken bolt that holds the coil on. The choke linkage is broke. Needed to build an adapter plate for the air cleaner. Oil gauge is in the same place. Think I will build a bracket for the temp gauge and mount it in the same hole. Needs a thermostat. Was a neat project.
Lon, I only moved the oil pressure because of the mower lift cylinder was in the way.
We would love to see pictures. ![]() Bill B |
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
I never cease to be amazed at the "designer things" you do to the tractors I sold.
At a tractor pull I saw a CA with a D-14 engine. Worked fine and pulled very well. Good Luck! Bill Long
