AC B
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: AC B
    Posted: 18 Jun 2017 at 5:23pm
Can the front crankshaft seal be replaces without taking the gear cover off? Does anyone know the part number for a speedy sleeve for a B front crankshaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 2:14pm
Bump
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 2:33pm
Ted, I don't know the part numbers. When I would need one I just called Sandy Lake and told Brenda than I needed the front crankshaft for a B.
You can change them without removing the timing cover. You will need a hooked seal remover to get behind it.
tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbird Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 2:38pm
speedy sleeve for a b is national moog  99150   1.497 -1.503 shaft  federal mogul
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 5:03pm
Thanks a lot.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 5:28pm
I just filled in the spiral with JB weld and filed it smooth. Almost 1 year later, still no leaks.
