Johnson grass |
acd21man ![]() Orange Level ![]() ![]() Joined: 07 Jan 2010 Location: tn Points: 831 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jun 2017 at 6:26pm |
I have some really nice orchard grass. I mean it is pretty but it has got a lot of Johnson grass we have had a lot of rain the last weeks and it really took off but I mowed it last night. Sooo.
I have a wick bar that I have never used that I can go in and hopefully kill it. If I could spray it Is there anything that will kill the jg and not kill my grass |
Dnoym N. S. Can. ![]() Orange Level Access ![]() ![]() Joined: 03 Oct 2009 Points: 544 |
https://www.gardeningknowhow.com/plant-problems/weeds/controlling-johnson-grass.htm
Recommended Johnson
Grass Herbicides
Successful Johnson grass control may include the use of Johnson grass
herbicide. Post emergence products as “fluazifop (Fusilade II),
sethoxydim (Vantage), clethodim (Envoy), and imazapic (Plateau)” may be
effective in outlying areas of the property. Glyphosate (Roundup) may
work as Johnson grass control near the lawn, but can damage surrounding
turf. Read more at Gardening Know How: Controlling Johnson Grass – How To Kill Johnson Grass https://www.gardeningknowhow.com/plant-problems/weeds/controlling-johnson-grass.htm hth B:-) Dnoym Controlling Johnson
Printer Friendly Version
Image by Don O'Brien
By Becca Badgett
(Co-author of How to Grow an EMERGENCY Garden)
Johnson grass (Sorghum halepense) has plagued farmers since its
introduction as a forage crop. This invasive and noxious weed has gotten
so out of control that many states require landowners to kill Johnson
grass. If you are a landowner bothered by a troublesome invasion of the
perennial weed, you probably just want to get rid of Johnson grass.
How to Get Rid of Johnson Grass
As with most invasive weeds and grasses, using multiple strategies
usually works best for Johnson grass control. This means that you may
use a Johnson grass herbicide program along with other kinds of Johnson
grass control methods. This is fitting, as Johnson grass reproduces and
invades crop areas in two ways, spreading both by seed and rhizomes to
overtake farmland and other areas of your property. The rhizomes of
Johnson grass are identified by thick cream-colored rhizomes, covered
with orange scales.
Herbicides alone are usually not enough to be an effective Johnson grass
killer. When combined with cultural practices that prevent the spread
of rhizomes and seeds, a Johnson grass herbicide program, with repeated
applications, may provide enough Johnson grass control to eliminate it.
Tilling the soil in fall following the harvest and followed with an
herbicide is a good start to kill Johnson grass. Rhizomes and seed heads
brought to the surface by tilling may be destroyed in this manner.
The seeds of Johnson grass that are missed during the applications can
remain viable for as long as 10 years so it is best to prevent the seeds
from being spread in the first place. Take steps to prevent the spread
of seeds and rhizomes to areas that are not infested. Digging clumps of
Johnson grass in the yard or small garden is a start. Dispose of the
clumps where they cannot reseed or spread. It is best to do this before
the grass goes to seed, to further prevent the spread of the seeds.
When Johnson grass grows near the lawn, keep the turf thick and healthy
to discourage the invasion of Johnson grass. Take a soil test and apply
recommended amendments to keep the grass growing. Reseed thin areas of
the lawn and mow at the proper height for your variety of grass to keep
it healthy and competitive against the Johnson grass.
Recommended Johnson Grass Herbicides
turf.
Read more at Gardening Know How: Controlling Johnson Grass – How To Kill Johnson Grass https://www.gardeningknowhow.com/plant-problems/weeds/controlling-johnson-grass.htm Edited by Dnoym N. S. Can. - 08 Jun 2017 at 7:38pm |
Craig/insoh ![]() Orange Level ![]() ![]() Joined: 26 Mar 2010 Location: Waverly,ohio Points: 229 |
Is this in a lawn or hayfield?
It's a hay field I have 70 acres of orchard grass and it's really good quality and it's all clean but this field. I have one field and it is about 15 acres and I'd say 3 acres is Johnson grass in clumps all across the field
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10694 |
I would like to know also. I have a similar problem with it here. Thanks Tracy
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3005 |
Nothing wrong with Johnson Grass for hay probably as much or more feed value than
the Orchard Grass.I know when I turn the cows or goats in a new field the Johnson Grass in one of the first things they eat. |
dt1050 ![]() Orange Level ![]() Joined: 05 Jul 2011 Location: central pa Points: 1078 |
bottom part of our hay field was almost always wet, we were able to bale it a few times and it was mostly johnson grass, tall thik johnson grass!!! the goats and cows loved it. |
Trinity45 ![]() Orange Level Access ![]() ![]() Joined: 17 Mar 2014 Location: Kentucky Points: 1820 |
Most people around my parts will not buy hay if they think it has Johnson grass in it. They are afraid the seeds will get spread around. It has become an invasive plant that most people want to get rid of.
It's illegal in tn to sow Johnson grass in less it has changed in the last few years.
It's hard to sell square hay and half a bale be Johnson grass lol. I guess I'm just going to take a wick bar to it and hopefully kill it. |
Cut it before it heads,a good stand of Johnson Grass will make about 2X the forage as other grasses in a growing season.It'll grow good in dry weather and on marginal land. If you want to get rid of it just graze it the cows will wipe it out,never give it a chance to reseed. |
Johnson grass is actually around 20+% protein if you don't sell the hay but feed it there is no need to kill it just cut it and bale it before it makes seed head if you cut it often enough it will starve the roots out and eventually get rid of it!
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9678 |
A lady representing the Speidel Weed Wiper system told me that a 4% solution of Round Up would kill Johnsongrass down to the roots.
A higher dosage would only burn the top and not kill the roots. |
