yikes and away
dt1050 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Topic: yikes and away
    Posted: 22 May 2017 at 10:11am
as I've posted I just purchased a 7016H. never owned a hydro or a simplicity lawn tractor, I removed the deck fumbled around a bit and managed to get the tiller hooked up. decided to try it out.  drove it over to a spot to till engaged the pto...nothing, dropped the tiller and it tilled till it hit dirt and stopped, gave it some more go juice....same thing....Angry back to the garage, so I shoved the hydro handle forward.....all the way and (had the throttle 3/4 open)...the front tires came up in the air and the old thing took off....I'm looking around how do I stop this thing...were's the clutch........ahhhh...finally pulled the throttle and the hydro handle down....ye haw...what a ride......
found out I didn't have the belt ran right for the tiller, a bit of internet searching and found the right diagram...mental note...keep the tractor slow and steady....
Post Options Post Options   Thanks (1) Thanks(1)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 1:20am
funny how easy it is to learn things!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 1:21am
and you didn't even bleed this time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 8:05am
no bleeding, just a lot of swearing......
