Joystick Install with Pictures
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Topic: Joystick Install with Pictures
    Posted: 21 May 2017 at 10:34pm
2-B's,CA,D15,D17,160,2-185's 8010
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 10:38pm
It's probably never happened here before but this project went over budget and twice as long.  Loader works great and is nice to free up the rear outlets.   Went ahead and replaced all the lines on the loader.   The seat is next.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 2:50am
nice job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:44am
Very nice looking job! Thanks for the pics! Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 8:45am
will you hafta take it all apart now, when you go to paint the tractor? lol
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 9:07am
oh, I see!Thumbs Up
Edited by JoeO(CMO) - 12 Mar 2018 at 9:39pm
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 1:22pm
Could the drain plug "T" be turned downward making it easier to drain?
(easier to hit a pail)
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2017 at 7:49pm
I rigged my return to go through the filter by putting a tee fitting in the lift valve return line.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 7:58am
I tried the tee down, but it lowered the clearance an inch and a half.  We use the tractor every once and awhile to clear brush.   Just thought tucking it higher would be safer.
Tim
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 7:13pm
On my 180 I split the joint connection under the floor next to the battery box and plumbed to the spool and back to the steel tube. Works like a champ.
Blue Bear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue Bear Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2025 at 9:01pm
was wanting to know the thread size of the hydralic drain plug where the return line goes in 1/2 ip or what is it please!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2025 at 9:15pm
1/2" pipe thread.
This page was generated in 0.172 seconds.
