1939 AC B
GWHunter3333 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GWHunter3333 Quote  Post ReplyReply Direct Link To This Post Topic: 1939 AC B
    Posted: 28 Apr 2017 at 12:15pm
Hi, I just bought a 1939 Allis Chalmers B and it started ok for the 92 year old man that sold it to me but he had the magic touch. The hand crank slips out of the slot when cranking so you can't turn the motor easy. The hand crank it self is in good condition, it's the slot inside that is worn out. Can that be replaced? I can't find the part but I did find one forum where someone said to just weld it back into shape and grind it to fix it. Has anyone ever done that?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 5:39pm
the slot is made into the front crank shaft pulley. Would need to pull radiator to get access.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2017 at 5:40pm
ALLIS CHALMERS WC TRACTOR CRANKSHAFT PULLEY AC WC
Post Options Post Options   Thanks (0) Thanks(0)   Quote GWHunter3333 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 3:47pm
Thanks Steve. I'll have to pull the radiator to get the crankshaft pulley off so once I get to that point I'll decide if I want to try to weld on it or not. Appreciate the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 5:27pm
I doubt it needs weld, unless the "ears" are broken off. A die grinder with the right stone or burr could possibly fix it right up, but you would probably have to have it off and on the "bench" to work on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 9:09pm
Sometimes they are a PITA to get off....... I think I might consider reworking with a die grinder as Tucker said... I would think you could do it on the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GWHunter3333 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 10:10pm
I will post a pic asap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 10:12pm
GWH-- the pulley is cast. PUll too hard with a jaw press and you will break off the edges...  look close at doing it in place.. Don't remove unless you need to change the crank seal for leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GWHunter3333 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 10:14pm
appreciate the tip
This page was generated in 0.234 seconds.
