alchol pulling tractor questions
NNYACAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NNYACAL Quote  Post ReplyReply Direct Link To This Post Topic: alchol pulling tractor questions
    Posted: 15 Jul 2010 at 8:42pm
I am presently pulling a wc with a gleaner "e" and want to convert it to run on alchohol. Has anyone out there already done this and what was the gain and approximately what jet size would be used in a stock carburetor?
NNYACAL
G,IB,B,C,CA,RC,WC,WF,WD,WD45,D14,D17SERIES 1,2,4
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 8:53pm
And your local antque club allows alchohol fuel???? sure wouldn't happen around here.
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2010 at 9:10pm
The big issue with alchohol fuel is that it is hard to get set right because the temperature changing outside effects it so much.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2010 at 6:13am
If carb has a adjustable jet then richen it way up to fouling plugs on gas . Thats a good starting point for alcohol. if it dont take it out and leave it out for a starting point read the plugs and then deteremine how much you need to increase the jets hole . usually its 1.7 times but sometimes its closer to 2.0 times
This page was generated in 0.210 seconds.
