h4 oild leak---need wrenches
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: h4 oild leak---need wrenches
    Posted: 11 Mar 2017 at 1:41pm
I want to start fixing my hydraulic leak. it is leaking at the fitting on the inside of the frame on the left side near dash panel.  normal wrench wont work. Whats the name of those wrenches needed and would anyone know the size of fittings. I'm guessing 1  1/8 or bigger.  thanks norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 2:32pm
Crowfoot wrenches and/or double offset open end wrenches. Crowfoot are set up for either 1/2" or 3/8" drive. To simplify when you take the old ones out save yourself some grief, remove the hose by splitting the sleeve or sleeve nut and breaking away with a chisel. May have to split on opposing sides with a cutoff wheel in a hand grinder. Most of the time the threads of the fitting will have taken a 'set' and will need more than a crowfoot to break it loose, removing the sleeve will allow using a socket, use a six point.
Edited by DMiller - 11 Mar 2017 at 2:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 2:36pm
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 2:51pm
Boy Dave, there's some good stuff laying right there.
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 2:56pm
I take an long open end wrench and heat it on the open end and bend it on a tight 90 degrees. you can slide it on the nut and use big adjustable wrench to turn the bent one. I have a John Deere 450 c loader and that is about the only way to get some of the hoses in the frame arms out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 3:51pm
That was a PITA, two full days hacking and installing!! ALL the loader hoses replaced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 4:53pm
I see your from herman dave.  My granddaughter just started teaching there this year. Seems like a quiet town. She likes it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 5:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 7:21pm
No room for them. thanks  norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 7:30pm
Hermann, Gasconade County is wonderful. My US ancestry started in Gasconade county in the 1800s.
I bought the less expensive set knowing I would have to slightly alter(round corner, trim ends) for what I needed:
http://www.northerntool.com/shop/tools/product_200012174_200012174
Edited by DMiller - 11 Mar 2017 at 7:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 7:59pm
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 11:41pm
I did the same thing as Randaleky did, after I broke a crows foot.
This page was generated in 0.162 seconds.
