OC Steering Problem
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Topic: OC Steering Problem
    Posted: 28 Feb 2017 at 2:33pm
I work for a vegetable grower with a JD 2840. It steers but there is a lot of play in the system which causes the tractor to wobble when you are trying to travel in a straight line. I have checked all bushings and tie rod ends and the problem appears to be in the steering motor. I can turn the steering wheel 180 degrees or more before the main arm starts to move. The local John Deere dealer is of no help. They say they can’t fix it. They told me to buy a new tractor.
I purchased a reconditioned unit from All States, but it does the same thing. I know this problem has been on here before. Just trying again.
Thanks for any advice and help.
See Video link.
https://youtu.be/chteMr-zPKc
Edited by ibleedorange - 28 Feb 2017 at 2:35pm
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 5:47pm
video is marked private...Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 8:41am
I believe the video is public now. Sorry first time adding a video to YouTube.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 9:29am
I'm certainly no expert on these but I would first check the preload on the front wheel bearings to make sure all is good there. I think I would next jack up both front wheels and see if could tell if any slop exists outside of the steering motor. It may be that the steering motor is the culprit and needs a rebuild.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 11:07am
Bearings were a little loose. Tightened them up. Everything to the steering motor seems tight.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 3:54pm
Add some toe in and SLOW DOWN !
 Is this a hydrostatic steering or hydraulic assist. Is it possible the cylinder is getting air in it from a cavitating pump or bad suction hose?
