allis 5020 |
dt1050
Orange Level Joined: 05 Jul 2011 Location: central pa Points: 1078 |
Posted: 27 Feb 2017 at 10:55am |
I don't suppose anybody has a steering pinion for an allis chalmers 5020. Agco part# 72098090. number 23 on the diagram.
dt1050
Forgot to mention it's a 4x4
lowell66dart
Orange Level Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Wenger's shows out of stock now but may be worth calling.
GARY(OH/IN)
Orange Level Joined: 19 May 2010 Location: Findlay,Ohio Points: 917 |
That looks very similar to the 5015 steering assembly if that helps any.
allis1221G
Orange Level Joined: 10 Apr 2013 Location: Hudsonville Points: 638 |
I have one if you have no other luck.someone called about buying it but not heard back.
dt1050
it was a few months ago I noticed my steering wheel was raising up when I turned right. It would raise up so high it the pinion would pop out of the steering gear. when I took it apart. (which is a pain in the ....) I noticed the snap ring broke allowing the bearing to slide down the pinion. the pinion is a bit chewed up and the groove were the snap ring went wasn't much of a groove any more. I had a fella who was gonna braze a ring on it, but I didn't want to take a chance of taking the temper out of the pinion and it brake.
I took a small file and teadesly filed the groove for the snap ring until it would hold a smaller snap ring, put a washer above it, new bearing greased every thing and put it back together. so far it has held up. Thank you for the replies. I have wengers looking for one just in case. Allis 1221g, I would be interested in buying it if your still looking to sell it. I don't know how long mine will last and I can't be with out the tractor, especially with planting season coming up. She's the only machine I have. |
GARY(OH/IN)
Yes, that may be the hardest thing to repair on that tractor.
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2960 |
I have a couple AC 5020 parts tractors.
dt1050
If anybody has one for sale I'd be interested. I don't know how long my repair will last and I'm not planning on getting rid of the allis any time soon.lol
Gary Burnett
I'll sell parts off the 5020 and I also have a 4WD front end I took off a MF 220 should be the same as the front on your tractor,it had problems with the left front spindle. |
dt1050
pm sent.
dt1050
After getting the RIGHT parts! the 5020 is back up and running. apparently the previous owner had issues with the steering pinion and must not of found the part so he engineered it!
the pinion in my tractor was 1/4 inch less in diameter and had a bushing manufactured to fit between the pinion and the bearing. the steering shaft was also milled down to accept a smaller u joint! I was able to get the original parts from Gary and now the steering is tight with no play. Sure hope there ain't a lot of them Frankenstein parts in/on this machine. Thanks for all the help dt... |
Sdwight
Bronze Level Joined: 09 May 2017 Location: Michigan Points: 6 |
I'm also interested in one for my 5030. Posted a few days ago. I don't know how this works but I let me know what I need to do to contact you directly
