b aliis repar |
wkiheri
Topic: b aliis reparPosted: 19 Feb 2017 at 10:49am |
What is the best way to fix a stripped out bolt hole that holds the draw bar on a b allis? Is there room inside the case of the final drive to run a 9/16 stud all the way through and put a nut on it inside the case. Or will a heilly coil work. Or do I have to dill and tap it to the next size up , and that entails drilling the drawbar and that is pretty hard steel.
AJ
Posted: 19 Feb 2017 at 11:00am |
Just go to the next size up. Been there done that... sucks but there are harder ways.
Can't fix stupid
Gerald J.
Posted: 19 Feb 2017 at 12:53pm |
A carbide masonry drill should cut the hard steel drawbar.
Gerald J. |
1939Dodge
Posted: 19 Feb 2017 at 4:02pm |
Try the helicoil first. Nothing to loose... The drawbar lick does all the work, the bolt just holds it all in place. No need to go crazy with it right away...
Besides, it's still winter. |
Joined: 11 Sep 2009 Location: illinois Points: 89220 |
Posted: 19 Feb 2017 at 4:23pm |
I have drilled out the stripped 5/8 inch hole, rethreaded to 7/8 and Loctite in a thread insert with a 7/8 OD and 5/8 thread ID. Not a helicoil, a real threaded insert. You don't have to worry about drilling thru to the inside of the case. There is only heavy gear lube inside. You can put thread dope on the bolt when you reinstall.
Posted: 19 Feb 2017 at 4:27pm |
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54716 |
Posted: 19 Feb 2017 at 6:25pm |
Yeah, those EZ locks are the cat's meow. Much better than a heli-coil, and you can loc-tight the EZ lock in, and use never seize, on the bolt, if you want to...
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 19 Feb 2017 at 9:03pm |
I was going to "chime in" with some advice on my favorite. However, when I read the other responses I would suggest you listen to them very carefully. It looks like they have thoroughly covered the situation. You do not have to overtighten the bolt. Be certain you have a good lock washer on it so it will not come loose.
Just remember, as said above, the the Stud only holds the bracket in place and allows the drawbar to be adjusted up or down. The dowel does the actual work of holding the drawbar in place and taking the burden of the pull. Take good care of my favorite. Good Luck! Bill Long
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2043 |
Posted: 20 Feb 2017 at 6:27pm |
I switch the finals. While I am at it I replace the seals in the transmission.
