CA soot on hood
racin69z View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote racin69z Quote  Post ReplyReply Direct Link To This Post Topic: CA soot on hood
    Posted: 09 Feb 2017 at 1:47pm
I have a 52 CA that I recently repainted.  I installed a new stanley muffler with a rain flapper.  I am getting a lot of soot on the hood.  Before I painted the tractor it had a straight pipe with a turn out away from the tractor.  I never recall getting soot on the hood, but the tractor looked so rough I may not have noticed.
I like the way it sounds now, but I need to get rid of the soot.  Does anyone have any insight?
Thanks
Lynn
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 1:51pm
Put a turn out on the muffler would be the only solution.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 2:12pm
May also wait until the "new" wears off the muffler?
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 2:37pm
Run some fuel additive it might be from the great gas that we get now
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 2:40pm
Plus your carb. may be set a 1/4 to rich.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 2:48pm
I had the same problem after I painted my WD45. Sometimes starting, I'd get a little blown out and deflect down on the hood. I went to NAPA and bought a 90 degree exhaust pipe and cut it to blow off to the side. no more soot.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 3:00pm
Minor leak at the muffler/ manifold connection?
Post Options Post Options   Thanks (0) Thanks(0)   Quote racin69z Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 3:20pm
Im pretty sure its coming out of the top.  I will try a turn out.
Thanks
Lynn
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 5:35pm
Lean the mixture out a bit and run some Seafoam thru it. If there is soot coming out, there is soot inside for whatever reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 6:26pm
If you don't run it very long, it might be condensation, carrying the soot out.  Always run long enough to get to operating temp.  Might also want a turn out on it, for running cold...
Post Options Post Options   Thanks (0) Thanks(0)   Quote racin69z Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 11:42pm
I have the marvel carb with only idle mixture adjustment. I will double check the adjustment. Has anyone ever found the need to run a smaller main jet on a stock engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote racin69z Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 11:44pm
One thing i have never touched is the timing. Its always started and ran good so i never fooled with it. I replaced the points condensor cap rotor plugs coil and wires just never adjusted the timing
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 5:46pm
Nice lookin 45 there Dave, big rears and especially those big multi-ribs on the front really set her off.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2017 at 2:17am
if it's kept outside, it'll do that
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2017 at 8:39am
Condensation. On a cool day with plenty of humidity it's going to happen for a minute or so until the muffler warms.
