stuck injector
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: stuck injector
    Posted: 01 Feb 2017 at 4:08pm
Anybody have a suggestion on how to loosen a stuck injector in a black 7580 head? I have been soaking it with penetrating oil and tapping it lightly and still can't get it to move at all. Would it be better if I ran the engine to operating temp and then try to move it? Also, it is the #2 cylinder, not the easiest one to get to either!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 4:26pm
Bosch injector?? or A-C injector??
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 5:09pm
Bosch
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 5:37pm
There is a pulling tool made just for that job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 6:44pm
Would a service manual have a picture of the tool in it? I have several Allis/OTC specialty tools that I got from a dealer closeout years ago and some I still haven't figured out yet!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 6:56pm
Make a adapter for a slide hammer.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 7:40pm
Will  the treads on top of the injector be strong enough to pull from?
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 8:37pm
had some side hammer would pull, had some pull head and beat out
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 9:59pm
Check to see if your nearest injection shop can borrow tools…they should have a fitting to go onto a slide hammer. 2.5 - 5 lbs hammer if I'm not mistaken?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 10:16pm
Crude but effective.
Edited by Lynn Marshall - 01 Feb 2017 at 10:18pm
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 9:17am
after loaning out our tool and never getting it back, the guys used a inj nut - welded an all thread sae to the top - then used a back plate off a Frigidaire compressor , drilled three holes, put studs on the out side two for legs and the nut/washer as in the above picture. HINT! - while pulling on the injector use a air chisel with a tip ground to fit the body, turn the pressure down and vibrate the injector as pressure is applied.  (same procedure used by deutz rebuilders to remove  jug / head bolts rusted at the block by fertilizer etc. )
Edited by tbran - 02 Feb 2017 at 9:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 7:04pm
Got it out! Thanks for the pic Lynn, I hope you don't mind me copying your design.
