1300 Field Cultivator Shovels
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Topic: 1300 Field Cultivator Shovels
    Posted: 14 Jan 2017 at 4:44pm
Going to put new shovels on my 30 ft 1300 this spring. What does everyone like to run on theirs? Shoup has 6, 8 and 10 inch ones for sale. Current spacing is at 6 inches between the shanks.
Anyone ever spaced the shanks out a bit more, then ran bigger sweeps? I think this would help trash flow quite a bit
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
charlesbendal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charlesbendal Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 5:11pm
We have a 30ft Krause and we used to run the narrow roughly 2in wide ones you can flip. This year we switched to the 6in sweeps and they do a little better job. Our shank spacing might be slightly wider than yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 6:20pm
Get a 1400 Chisel-vator if you want 7 1/2" or 9" spacing (they were available both ways). Try and run any wider shovel than 6 inch and you will plug more often AND overload the shank bending it backwards in some soil conditions.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 6:41pm
I always ran 6" on mine! thanks; ac fleet
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 6:18am
I had 6" on mine until I replaced them with used 9" ones. It is twice the machine now. Not to contradict the Dr, but the wider shovels reduced the plugging and it does a better job. I haven't broke a shank yet and its been that way 6 years.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 10:28am
Some of the Shoup shovels have blunt curved edges, wont' cut until they get a few thousand acres of wear. The square nose is all that is sharpened. Lousy for cutting weeds. I mounted a set of them and after their failing to take out weeds I spent half a day under the field cultivator with an angle grinder putting a cutting edge on them. That is their Marathon I sweep. The other sweeps probably have a sharp leading edge but I've not bought them.
Gerald J.
