wd45 exhaust gaskit
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: wd45 exhaust gaskit
    Posted: 14 Jan 2017 at 7:25am
I'm replacing the manifold gaskit today, my question is do I use any type of sealer between the head & the gaskit. I don't see how it can seal with a thin piece of metal against the head. Seems strange because the gaskit is between the thin metal & the manifold. thanks in advance, keith So. Va.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 7:43am
i used walker exhaust sealer part #35959 on mine.available at most any parts store.put it on the manifold surface after prepping surfaces.helps keep gaskets in place when putting back together and fills any pits or voids.used it for years on many different gasket less manifolds,cars,trucks,etc.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 7:48am
     The metal goes aganist the head with no sealer.
Clean the head and manifold real good.
Check the manifold for pitting and use a straihjt
edge to make sure it is straight where it fits
aganist the head. If it isn,t have somebody
plane it down.
                John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 8:42am
thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 4:39pm
NEVER put anything on it except a piece of string to hold it in place till you got a bolt started.  Then they started using studs, so the string went out the door too.  Nope, don't need nothin.  Just make sure you use a torque wrench and then re-do it after it's run a little and hot!   Then once more the next day again.
This page was generated in 0.101 seconds.
