190 tach drive
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Topic: 190 tach drive
    Posted: 09 Jan 2017 at 1:51pm
Im in need of a tach drive for very early 190 mine is worn out the tach cable just spins inside it. Agco doesn't carry them anymore.
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 2:29pm
I think Norm Meinert has them. I had a 190xt with the round fiber wheel and never had good success with it. I may have needed a new tac so becareful of it.This was when I used the tractor all the time for field work so it was not that old.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 8:47pm
Is yours alternator driven or cam driven?
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2017 at 8:58pm
Also could be distributor driven
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 12:03pm
Mine is cam driven.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 12:05pm
I just put a new tachometer and a new tach cable in it, only thing left is this cam drive.
Edited by acplowboy45 - 10 Jan 2017 at 12:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 1:02pm
If the end of your cable is square, you probably need a little plastic adapter with the tab on it. I'm not sure if Agco offers it anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 3:09pm
My tach cable is square and it has a tab already on the end of it. So ur saying there is a plastic tab that goes down inside the tach drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 6:42pm
Your tach drive could be extremely worn but I am somewhat doubtful of that. You may still need a small sleeve (adapter) to take up the slack.
