Engine opinions for 210
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Engine opinions for 210
    Posted: 23 Dec 2016 at 7:45pm
I have a 210 with electrolysis that I'm going to be putting a different engine in. I like keeping things original, but I have a 3500 series block that I could do a full overhaul on. My other option I have is a low hour 3750 out of a n5 combine. My question is, what would it do to the value of the tractor if I went the 3750 route? I've been going back and forth so I would like some other opinions. I will probably paint the tractor afterwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 8:17pm
Plan on selling?Plan on selling to a purest? Just gonna keep for your own use? I'd put the combine engine in it but that's me.I don't git rid of nothing.
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 8:31pm
I have put in later engines in 220s but if you were not a ac nut you would not have known.Electric tach water connections etc it is all about how you do it fast and easy will look like crap
BKarpel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 9:17pm
You could use the engine that's in your 210 and rebuild it that would keep it original and correct. We remove the sleeves and bore out the bottom of the block and install a repair sleeve. Then we push in new sleeves. This is a common problem and have repaired many AC blocks this way. Remember to install a coolant filter.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 10:40pm
I agree. After you rebuild your 3500, you'll know exactly what you have. Save the 3750 for something bigger like 7080, 7580...
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 5:53am
I'm kind of a purist and a hot rodder at the same time. Have a D-21 and 210 with original engines but my 220 has a newer 3500 MK II engine and I've changed the water pump and added an intercooler. It's my 220 XT that you may have seen in OAN.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 8:49am
Usually what is the most practical for you works the best.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 9:03am
I'm not sure if I'm going to sell it or not. I saved this tractor from going to the scrap. I didn't want to see it get parted out either because it was somebody's pride as they put a chrome stack and air cleaner on it and put a name on it. I've held onto this 3750 for 4 years now and just hate seeing it set in the shed with 1500 hours. But I think I'm going to continue with the plan on rebuilding the 3500.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 9:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 9:12am
If it has 2-sleeve O-rings (which it probably does) just overhaul it and the new sleeves will have 3-Orings. Block will be OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 3:57pm
HMMMM! I like Doc's answer
This page was generated in 0.127 seconds.
