Allis Chalmers 710 H
MiKe04gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MiKe04gt Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 710 H
    Posted: 20 Dec 2016 at 8:54pm
I have an old Lawn tractor that was given to me. I am not sure about much on it. I know it is a 710 H, with a K301 Engine. I got it rebuilt the carb, New points, coil, Rewired it. I now have it running pretty well. However the part that bolts to the flywheel with 4 bolts, then to the drive shaft disk with 2 bolts broke. I don't know what this part is called to try to fine one. It looks like one of the bolts worked loose, then sheared both bolts off inside the part. However when it broke it busted out the threads and now is no good. thanks for any help.
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 10:40pm
Mike:
Might also want to post on Simpletractors.com - between these 2 websites I am sure you will find the help/parts you need.
Welcome to a fantastic forum!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 11:22pm
Should be some spacers bolted through what looks like a white plastic, or fiber looking disc then bolted to the drive shaft. That little disc thing brakes. Do you still have the spacers.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 6:35am
Didn't think they made a 10 HP with Hydrostatic.
Only 712H and 716H
Gary
http://www.simpletractors.net/models/ac_700_series.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MiKe04gt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 11:37am
Sorry, In the daylight hours I looked and it is a 712H
Post Options Post Options   Thanks (0) Thanks(0)   Quote MiKe04gt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 2:39pm
I think it is called a Front drive adapter. I cant figure out how to upload a Picture.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 4:03pm
An in stock item at most Simplicity dealers! Same disc used on all the L&G tractors. You can double them up for extra strength when pulling. And as Mike said they also have a coupler steel spacers and Heavy flat washers used on them. I've got a new old stock kit #103052 with new bolts, HD washers 1 disc and spacers left for $30.00 plus $8.00 postage
online they want $37.75 plus shipping for them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 4:20pm
Can you show me a picture farmtoybuilder we stock them separate. Never seen the kit
Post Options Post Options   Thanks (0) Thanks(0)   Quote MiKe04gt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 5:09pm
Can you send me a Picture? Mine is a Cast iron piece Engine bolt holes is 4- 3/8" Bolts 3" Across on Center. then the 2 for the Drive shaft is 2- 3/8" bolts 2½" on center. Do you accept PayPal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MiKe04gt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 5:20pm
I was able to fine all the spacers and thick washers on each side of the fiberglass disk. But new ones wont hurt either
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 7:50am
The disc is 2 1/2" centers. Yes we accept pay pal. Email us direct at farmtoys@sbcglobal.net I'll try posting a picture. You can purchase just the disc from dealers. I don't have any separate ones left. I should probably keep this one as we use a few of ours too! Let us know if you want it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MiKe04gt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 8:04am
That's not the part I need. I need the cast iron part that bolts to the flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 9:21am
I thought you broke the disc. As that's common! Have never broken a hub. I don't have any of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 10:07am
Yea sorry I thought the same. I might be able to come up with a used one, have to look.
Jeff do you know if there all the same on the kohlers (10,12,14,16hp)
Edited by Mikez - 22 Dec 2016 at 10:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 12:06pm
All same for the single cylinders!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 3:12pm
go to simplicitiymfg.com  and go under support will take you to a place to type in your product number and serial
