Radiator Overflowing Question |
Page 12> |
| Author | |||
BenGiBoy
Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
Topic: Radiator Overflowing QuestionPosted: 19 Dec 2016 at 8:09am |
Hi all,
So I recently got my B running again, the only thing is that when the thermostat gets up to temp and lets antifreeze through, it dumps a whole bunch out of the radiator overflow. So.....does this mean that the radiator cap is dead? I could get a new cap, or it would be better just take the thermostat out. I wanted to leave the thermostat in, because it will never heat up in the winter, especially like the winters we have had for the last few years with temps under -20 degrees F..... The thermostat was just installed during the rebuild. It didn't have one for a while.
'39 Model B
Tractors are cheaper than girls, remember that! |
| Sponsored Links | |||
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24889 |
Posted: 19 Dec 2016 at 8:26am |
hmm I got the same problem with D-14 #1... I 'thought' it was a sticky/bad stat BUT it works fine out of the tractor, seems once it overheats once, it's fine....
I could swap with another but it's a tad coool here today..... Also checked belt, it's tight, rad was cleaned this summer, hose are fine.... Can't think what else to do.. besides getting #5.... Jay |
Butch(OH)
Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Posted: 19 Dec 2016 at 8:41am |
Is the engine getting hot or just losing some coolant? How much is it actually losing? A Dixie cup full looks like a lot when it spits from the overflow and runs across a clean shop floor, LOL. You may be simply suffering from parts mixing? I cannot remember when the B went to pressurized radiators? but our 38Band 41C are both non-pressurized. Does your radiator cap look like gas cap underneath? or does it have a rubber seal and spring like a "normal" radiator cap? The non pressurized systems didn't have thermostats originally and dont like them added, I would remove it. Instead they used shutters out front and you adjusted them per need. Any of the non pressurized systems will lose coolant if filled to the top when cold thermostat or not. Let them lose what they want to lose and dont fret it. if the core is covered cold you are good to go. If your tractor has been converted to a pressurized type radiator and cap you may have other issues, Bs and Cs are not noted as warm runners, usually a person has troubles getting them up to temp.
Edited by Butch(OH) - 19 Dec 2016 at 8:42am |
BenGiBoy
Posted: 19 Dec 2016 at 8:48am |
I do not know exactly how much it loses, but I had to pour at least a gallon into it after the one time that it dumped. It is a '39, but has been converted to a pressurized radiator at some point, and it has a regular pressurized cap on it.
I could take the stat out, but I would rather leave it in... I do have a set of the shutters but I do not know if they will fit on this radiator, I will definitely give it a look though.
'39 Model B
Butch(OH)
Posted: 19 Dec 2016 at 8:56am |
A gallon is a LOT and definitely abnormal. The later tractors with that engine platform had a thermostat by-pass hose, do you have one? Not sure when that was added, a B and C expert will have to chime in. I know the D-14 and 15 had them and have seen them on CAs. Again you may be suffering from parts mixing
BenGiBoy
Posted: 19 Dec 2016 at 8:57am |
No, I do not have a by-pass hose.
What do you mean by parts mixing?
'39 Model B
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3086 |
Posted: 19 Dec 2016 at 9:07am |
I gallon is abnormal. My uncle used to tell me to leave an inch or 2 empty from the top of the radiator for flow. If you fill I all the way, you will overflow a little, BUT not a gallon, you'll maybe lose a pint.
Butch(OH)
Posted: 19 Dec 2016 at 9:09am |
Many changes were made over the time those tractors were built and the same basic platform was used to the CA and the engine lasted all the way to the D-15II. There is a bunch of Frankenstein tractor out there made up from this and that and a person could call some of them a B, or a C, or maybe even a CA depending on which end you chose to use for naming it. Parts will often bolt up but may cause other problems if some related parts are not also changed. Pressurized vs non cooling systems is a good example. Another example that comes up every now and then is backwards steering tractors. Turn the wheel to the left and the tractor goes to the right. This happens when B and C steering boxes and arms are used randomly.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12043 |
Posted: 19 Dec 2016 at 9:17am |
I would lose that pressurized cap and put a standard cap on it. If there wasn't a thermostat in there, I would leave it out. The coolant will warm up faster with it out because there is no restriction in the system to slow the coolant down in the radiator. A lot of people get that backwards. If you have a overheating problem, you want the thermo in to slow the coolant down in the Radiator so the Rad can do its job. If you're having a problem getting the engine to warm up, remove the stat so the coolant goes through the engine faster and picks up heat from the engine block. As Butch mentioned, if your B is a 38/39 I don't think they had thermo's in them till later on in production. Sometimes if you have a little bit of coolant being pushed out, it may have been from a air pocket and the cooling system is just leveling itself out. A gallon is way to much. A small cup like Butch mentioned would be more normal to me. I think its because you pressurized the system. Just my 2 cents...
Steve@B&B |
Stan IL&TN
As Dave said leave the level a couple of inches from the top as there is no over-flow tank. If it still flows out when warmed up or if it overheats then yes you do have an issue.
1957 WD45 dad's first AC
BenGiBoy
Posted: 19 Dec 2016 at 9:18am |
Oh, okay. This is a B tractor, as fas as I know. I do not know what kind of radiator is has, but I do know that it is pressurised.
Maybe I should just take the thermostat out? It was working good until I put the thermostat in, it just ran cold. (and in the winter it was ALWAYS cold, at least for the periods of time that I ran it, I never ran it for a couple of hours....)
'39 Model B
Gerald J.
Posted: 19 Dec 2016 at 9:42am |
What is the temperature rating of the thermostat? The whole benefit of pressurizing the cooling system is that it raises the boiling point of the coolant. Permanent antifreeze also does that. Is the thermostat turned so the sensing side is towards the engine? Sounds like its slow to open and gets the coolant boiling so it flows really fast, faster than the radiator can take the flow. There needs to be air space in the radiator to allow for coolant expansion and radiator core flow resistance. The shop manual points out a couple other details.
That shop manual is on line at: http://www.geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf The page on the radiator is: ![]() Gerald J. |
BenGiBoy
Posted: 19 Dec 2016 at 9:50am |
It is a 180 degree thermostat. It seems a tad high, but that is the only temperature that I could find.
'39 Model B
BenGiBoy
Posted: 19 Dec 2016 at 9:54am |
I would have to check to make sure of the way that I had it put in, but I think that i put it with the long side into facing away from the thermostat housing, because that is the way I thought it needed to go...
Edit: The long end of the thermostat is facing DOWN, if I remember right.....sorry, I just realized that how I had it written was a bit confusing. Edited by BenGiBoy - 19 Dec 2016 at 10:19am |
'39 Model B
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 19 Dec 2016 at 10:07am |
the long side is generally facing the head or opposite direction of water flow.
Allis dave
Posted: 19 Dec 2016 at 10:14am |
a 180 degree is fine. Most cars are 190 - 205
BenGiBoy
Posted: 19 Dec 2016 at 10:20am |
I think that this I have it in correctly then....the water flows from the head through the thermostat housing to the radiator, right?
'39 Model B
CAL(KS)
Posted: 19 Dec 2016 at 10:45am |
yes, radiator flows top to bottom
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 19 Dec 2016 at 11:03am |
With a new thermostat and all cleaned up it is very possible that you had a good seal and got very little coolant into the block when you filled it the first time. That would explain needing a lot of coolant after the thermostat opened let the air out of the block. When liquid heats it will expand and run out the overfill tube if filled to the top. I do not see how it could overflow a gallon unless the engine got very hot to where it started to boil to develop air bubbles to get that kind of expansion. To have that problem you would have a plugged radiator. I would doubt that you had any more than an overfill problem the second time if your radiator is not plugged.
Dick L
Posted: 19 Dec 2016 at 11:15am |
You do not need a pressure cap on these tractors. They did not come with a pressurized cap. The C I mow with has not had a radiator cap on for two years. It popped off in a rough hay field and I have not put the one on that I bought to replace it.
Bill Deppe/AC Salvag
Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
Posted: 19 Dec 2016 at 11:24am |
I use a thermostat that fits into the recessed part of the thermostat housing on a WD45 and do away with the rubber portion, I then drill a 1/8" hole at the base of the thermostat to allow fluid to flow by. Maybe this would also work for this situation, especially with no bypass.
BenGiBoy
Posted: 19 Dec 2016 at 12:09pm |
Okay, that makes sense. Maybe that is it then. It was right after we had filled it for the first time, so maybe it is just an overfill problem, and it will cure itself if I don't fill it up to the top like it was before the thermostat was put in. I will run it some more today and see what happens. Thanks!!
'39 Model B
BenGiBoy
Posted: 19 Dec 2016 at 12:11pm |
Chuckle, chuckle. I could never run something without its cap, I would not think that is looks right, so I would have to put it on.
'39 Model B
Dick L
Posted: 19 Dec 2016 at 3:03pm |
I don't care much how it looks. I never put the tin back on it when I put it together over six years ago. It only has one fender also. To get on I put my heal on the drawbar and pull myself up on the rear tire and then scoot over onto the seat far enough to get my left foot under the steering wheel, scoot back in the center and take off. I haven't noticed any difference in how it mows with all the covers on or off. It starts instantly every time I want to use it as long as it has gas in the tank and has for six years. Here is a picture of it before I lost the cap. It was never tight from the time I put it together. It's starter battery is on the front of the walker cart. Edited by Dick L - 19 Dec 2016 at 3:09pm |
groundhog55
Posted: 19 Dec 2016 at 3:14pm |
looks to me if you lost a gallon you must have a head gasket or some internal problem.
BenGiBoy
Posted: 19 Dec 2016 at 5:15pm |
It was not in the oil, so I am 99% sure that DickL was right..... it had just filled up the block and head. DickL: That is quite the tractor, LOL.
'39 Model B
Gerald J.
Posted: 19 Dec 2016 at 5:44pm |
Read the last paragraph of the shop manual page I posted above. It says those B and C that are pressurized have a 7 psi cap. Its from a scan of Allis Chalmers form SM-3, I didn't find a date.
Gerald J. |
Gerald J.
Posted: 19 Dec 2016 at 5:46pm |
I've read on this forum that some Allis Chalmers tractor thermostats were specified to have a small bypass hole in the flange. A universal thermostat won't have that.
Gerald J. |
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 998 |
Posted: 19 Dec 2016 at 6:48pm |
If you lose that much coolant on a repeated basis you may well have compression going into the cooling system. Some compression leaks don't show up until the engine gets hot. If this is the case the exhaust gets trapped under the thermostat on warm up and the coolant is forced through the lower rad hose and out it comes at the top. If a compression leaks only occurs (like in a cracked head) while hot you wouldn't have the problem running the engine cold (without a thermostat). Secondly, without a thermostat any compression leak is able to escape immediately through a non pressurized cap. What I have described here is exactly the problem I had with a Perkins diesel. Once I put a little spacer in the thermostat and had the rad cap loose I did not lose coolant BUT the problem turned out to be a cracked liner.
BenGiBoy
Posted: 19 Dec 2016 at 7:00pm |
It is a thermostat specifically for a B, I believe that i bought it from Norm Meinart (I think that is spelled correctly), but I am not totally sure on that. So.....drilling a small hole in the flange would be a good idea? I was going to run it today, but it didn't want to start. ![]() I think that it might have a weak spark, and it was cold. Also, the starter might be drawing too much juice because it is partly dead from too much use. But it ran just fine on Saturday, and it coughed a little today, so it is getting something for a spark. It was warmer on Saturday though, so that might have helped. Edited by BenGiBoy - 19 Dec 2016 at 7:00pm |
'39 Model B
Page 12> |
