Update on A2 progress |
Sandknob
Orange Level Joined: 12 Sep 2009 Location: Oblong, IL Points: 2456 |
Posted: 30 Jun 2010 at 10:16pm |
I was able to get the drag chain (from cylinder to sieves) freed up tonight. I thought that I was going to have to take the throat off of it to fix it, but there was a cleanout plate under the throat that I noticed and I took it off and had easy access to the chain. After a little work it came loose. I also was able to free up the beater in front of the cylinder and now it spins very easy.
Next on the fix list is:
#1 Return clean grain elevator to factory position (it has the kit added to make it longer for extensions - I was told extensions were very hard on the axles on these so I took them off. If I were to add just one 1x8 extension around the bin would I have any problems?
#2 New hose for variable speed. What pressure does this hose run? Could I just use 1/2-5/8 copper tubing for this?
#3 Put the 330 head on and install the gathering snouts.
#4 Need to adjust the chains and oil them up real good.
#5 Need to install the set of rice tires I picked up (front and back) for $100. The old tires and rims are going on my WD45
#6 fix the lights and electrical system.
#7 clean and repair fuel tank
After looking at the list I know feel overwhelmed LOL!! Oh well some of it will go fast while the rest will take a little while.
Adam
Sandknob
Unit3
Orange Level Joined: 17 Oct 2009 Location: NC Iowa Points: 5559 |
That is a straight old machine you have. Most are all beat up. I have a small project that will get started after the 4th. It is an N7 that still has the engine. The 516 is stuck from sitting and I am told on another site that it will fit in a D21 on up. I am looking to put it in a 7080, IF, IF, it will run again. That's a Big IF. Your machine looks like it would be field ready alot sooner then my N7 ever could.
Steve M C/IL
Orange Level Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Unit 3 I think someone streched the truth when they claimed the 516 will "fit" a D21 & up.
