torque limiter question
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: torque limiter question
    Posted: 07 Dec 2016 at 9:59am
I need to put a new TL in my 7050 this winter and that got me thinking about this. Why do the powershift trannys use a pressure plate and the power directors use the Belleville spring? Is there a benefit to one over the other? Could the PP be used on the 7050?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 12:18pm
In the original design of the Power-Shift transmission, Engineers were concerned about possible Winter starting problems, and wanted a way to release the entire driveline to ease cranking speed concerns. Turns out, there never really was an issue, so there were never any fingers added to the pressure plate. As time went on, the last of the 7040-7060 Power-Shift tractors used the same flywheel and torque limiter as the Power Directors tractors. The pressure plate design won't fit in a Power Director bell housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 1:50pm
Thanks for the info
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 2:33pm
early 7020's  PS units had the light fly wheel  - we changed out several to the heavy flywheel with clutch type pressure plate to increase flywheel inertia for the PS and non stall when reversed...  just FYI   7020's could have both on a PS...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 3:19pm
I installed a combine flywheel (N-6 or L-2...can't remember) on an 8050 PShift once to give it some more hay baler flywheel torque.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 9:18pm
There is not enough room in PD tractors for pressure plate type clutch torque limiter.      MACK
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2016 at 7:29am
i have quite a time with my 7020 stalling in high reverse, where would I find a heavy flywheel in what model tractors? we have a local wrecker that may have one!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2016 at 8:13am
Just put the PS hub into the combine disc and it lined up? Think that would he the ticket for our chopper tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2016 at 9:10am
Nope. Still able to use the spring pressure plate and T L disc. Seems to me like that flywheel weighed just over 100 lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2016 at 12:23pm
Don't the big boys in tractor pulling add weight to the flywheels to make them lug better ?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2016 at 9:12pm
No, we put weights on fingers for centrifugal force to engage clutch. The more weights on fingers, the more pressure on clutch discs.     MACK
