Goodies on the trailer
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Topic: Goodies on the trailer
    Posted: 28 Jun 2010 at 9:57pm
I found a harrow and blade not far from home.  Between this disk and the one I already have, I think I can make a good one.  The blade is pretty rough.  I'll probably have it for sale after I look it over closer, if it is too bad I'll strip off the good pieces and make some more 12" blade extensions.
Adam
 hmmm... can't add pictures for some reason.  Sorry to get your hopes up, I'll try again after while!
Edited by NCAllisnut - 29 Jun 2010 at 7:17pm
BillyL(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillyL(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2010 at 10:22pm
Adam if you are busting up a disc I need one scalloped disc.I would be happy to buy a left over from you. I also need both of the tilt adjustment screw assemblies for a blade so if you tear down the blade and don't need those parts let me know. Are you going to Denton this weekend? Billy
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 7:01pm
Here are a couple of pics from last night...  better pictures to follow.
Sorry Billy, the tilt screws are the worst looking thing on this blade.  My disks are both pretty worn, but I'll send you a picture of what is left over.  It won't be anytime soon, it is too hot to play right now!
Adam
Edited by NCAllisnut - 29 Jun 2010 at 7:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 7:23pm
The disk has some odd features compared to the one I already had.  The front gangs are spaced differently than the rear gangs.  My other disk has 32 blades, this one has 24 - 2 gangs of 5 on front and two gangs of 7 on the rear.  Was there an option to set these up this way originally, or is this just some farmer's creativity at work?  The lift chain hooks that go in the lift arm latches look home made also.
Adam
Edited by NCAllisnut - 29 Jun 2010 at 7:27pm
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 7:54pm
Wide spacing on front gangs for better cutting, narrower spacing on ears for leveling. Very, very common in this area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 8:07pm
Cool, you learn something new every day.  Thanks Russ!
Adam
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 5:21am
The lift chain[s] look to be original, the pin bracket looks different then what I had on mine, and what I have seen in past, they look well done and stout. I think originally the bracket at top of chains did not require a lift latch on tractor, small u-shaped piece fit over end of lift arm and pinned.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 7:05am
I've never seen a yellow chain. I've got a couple of orange chains.
Dusty
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 7:37am
Congrats on your find Adam.
This page was generated in 0.067 seconds.
