Unstyled WF Fenders
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled WF Fenders
    Posted: 30 Nov 2016 at 4:42pm
Would anyone have a good set of fenders for a unstyled WF for sale? Thanks Zach
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 4:52pm
Are the unstyled WC fenders the same?  I have a brand new set... I know the styled fenders for the WC are different from the styled WF. Clamshell design is the same, but the mounting brackets are in different positions...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 5:03pm
Thay are not the same. The unstyled WF fenders are different than the unstyled WC fenders
Edited by ZachD89 - 30 Nov 2016 at 5:05pm
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 5:26pm
are they shorter then the wc fender' like a wc fender cut off at the back an the front' if so i have a set. very good ones..
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 6:09pm
The unstyled WF fenders are indeed shorter than the WC's When I did mine I used the inner panel from the old WF fenders and then put cut down (shorter) WC fender on them. I used pan head stove bolts to fasten them to the brackets and filled the screw driver slot with bondo to look like the rivets originally used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 6:16pm
sounds like the ones i have' the top are same as wc' an short' sure like to see one..
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 12:07am
Zach, we make new ones for a WF along with many other unstyled fenders, if interested please call and we can discuss building a set for you.  612-280-3397
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 6:14am
There ya go Zach! You won't be disappointed I can tell ya that! The fenders I have for sale are made by the Grams Bros. Workmanship is impeccable! They make some beeeutiful stuff! Now if ya we're talkin' about the ole' man, well, that's another subject...! LMAO!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 12:23pm
Your so kind little fella, I was going to be nice to you steve, but you make it difficult. Zach these fenders will be impressive on that WF, there is a set om my unstyled WF and they look good.
