Turbo for AllisChalmers HD3
Sheldon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheldon Quote  Post ReplyReply Direct Link To This Post Topic: Turbo for AllisChalmers HD3
    Posted: 26 Nov 2016 at 4:13pm
My dad had a Allis Chalmers HD3 track hoe which is now mine. i love the thing but it is under powered for the use i have for it. I'm looking for a turbo to add to the diesel engine on it's upcoming rebuild but i'm having trouble locating one. Does anyone know where I can find a turbo kit for this engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 5:43pm
You're on your own. I know of no "turbo kit" available for an HD-3. Maybe a fresh engine OH along with injectors and injection pump will liven it up a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheldon Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 9:38pm
Thank you. I thought I had read somewhere that people were using the D15 farm tractor (Which I believe is the same engine) for antique tractor pulling and many had added turbos. I just can't find the web site again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 11:06pm
the HD4 with the 2200 engine can be turboed - same engine was used in cotton picker and there they used a turbo .
 H3 is a light machine and IF you are overworking machine high HP output is going to make junk out of it quickly .
 Look for a larger machine it might be cheaper in the long run .
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 8:35am
As Coke said! Your better off to buying a bigger dozer! It won't stand any more power. Our 40 hp. 4wd JD tractor with loader will push more than the HD3 we have. And I hate even trying to use it anymore after using newer style Cat D4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheldon Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 10:21am
Thank you all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2016 at 7:41pm
depending on which hoe is on the machine - my HD4 used a AC 650 hoe with 14' reach and 24" bucket - the weight of the hoe caused the machine to ride on rear sprockets and not on track rollers - broken axles and worn case bearings and bearing races on both rear housings - about $300 of machining  on each rear case to get new bearing cups set into cases . Went through 4 axles also in time i had machine
allisguy.11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisguy.11 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 7:21am
check out Keystone turbos... just google them. they make kits for 45 gassers. I'm sure you could give them the specs and they can make up a turbo and manifold assembly for you. they may already have them. get out your pocketbook.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheldon Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 8:47pm
I have e-mailed Keystone several times and have yet to receive any reply.
This page was generated in 0.199 seconds.
