bulldozers and back pain
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Topic: bulldozers and back pain
    Posted: 13 Nov 2016 at 8:20pm
Anybody got an air ride seat on their dozer? If so, does it help? If yes, what brand? Haven't been on mine in 6 months. Last time I got off of it, I swore I would sell it before I would get on it again, but as usual, I've got some work to do that the helper can't handle. Any help or suggestions?
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2016 at 10:30pm
What do know? This topic started with dozers and back pain and ended with dozers and back pain. Was it all for the same reason? Hmmmm
HD6 Merv View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 12:24am
I was always told; if its hard on the man, then its bloody hard on the machine !
Try doing it abit more gently.
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:30am
I remember about 1980 that the Construction part of Allis was testing air ride and other suspension seats in the large 41B dozer for coal mines.... I though it was odd at the time... BUT I WAS 30 YEARS OLD....... Seats went over real BIG with the 50- 60 year old guys........ FIAT was a big influence at that time, and many of the tested seats were from Europe ......... don't know what difference that would make to you.. A good seat from a heavy truck would work OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 8:05am
Slow Down - watch the terrain - take the bumps and lumps slowly - look ahead of what is going on .
 Running loader and dozers didn't bother me as far as back - the HD4 got my feet confused as far as brakes and decelerator  being brakes were together unlike HD5 with space between.
 Then only spent limited hours per day on machines - trading off with shovel - transit - or truck.
1952Dan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1952Dan Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 12:19pm
Not sure about dozers yet mine still in repair mode . But riding mowers I have noticed after riding my rough and tumble Craftsman My back feels fantastic after a long 4 or 5 hour ride when a total wreck before the run .But not so after riding my smoothe cub cadet . It is too easy on bumps and adds no exercise. My dozer AC mod M has a fairly square shaped seat . if it is rough I may try buying some 4 inch thick memory foam and build a seat . if it works out then have it upholstered.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:35pm
Suspension does help.  I found that a little softer ride helps my neck muscles, less headaches.  Our HD11 has an old truck seat- it works ok.  Dad used to have a lot of back pain- he always strapped on one of those back support deals plus added extra cushions for lumbar support when he got on the cat.  When the pain got too bad he let me operate, it was great for me as a kid anxious to learn.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:48pm
Easily said until you actually have a bad back then you can't be gentle enough. I spent $1,200 or was it $1,300 on an air ride seat for my tractor as I was desperate for relief.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 8:18pm
 I'm not hard on my machinery, if I was I could not run the older stuff that I do! I've had back surgery once already and I've got a lot of hard years on this body. I just want to know if anybody has tried air ride on a dozer and if it worked for them. Lonn, I feel your pain!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:33pm
I bought a suspension type seat and put on my HD5 and on the FD5 - some spring give in suspension and adjustable for weight but not a air ride seat .
 On the HD5 I used a bucket seat from a Chev Pickup for years - the high back worked well when dozing but for loader it is all short work and hand busy so not much setting back and riding ..
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 4:52am
This is Thomas dad . you have a dozer blade use it ! smooth off A spot . if it's a rough ride it's the operator! use the blade to make you a smooth spot. started at this spot and work your way out . Either you can work the machine or the machine will work you.
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 12:14pm
My old 7G has almost 7 inches of serious foam padding in the base and four in the backrest, layered of dense to soft so does not kick the hell out of me in use unless I get rambunctious.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 1:28pm
"This is Thomas's Dad."
-or_
"This is Thomas, Dad."
In other words, who the heck is Thomas? I'm confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 7:15pm
My dad uses my account to post sometimes,
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 9:51pm
hi dad!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2016 at 6:52am
Ah, so, "This is Thomas's Dad", and Orange4ever = Thomas.
K.
Whew, I never would have got that.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2021 at 11:35am
My darn back got so bad, I sold mine. I hated to do it, love running it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2021 at 6:10pm
Still using them suspension seats on 2 machines - now bought a New Holland 655 Turbo skid steer and after running the BobCat S300 my learning curve has to come back , from crab steer joy stick to hand levers and foot control boom and bucket - and NO suspension at all in either
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 8:37am
Run several Cat 963 series machines and a few Deere rubber tire articulated now a days, two have bolted in seating and are brutal, three are suspension seats where still after a day with my aged busted up back am sore as all get out.  AGE is our culprit not so much machines, youth get bounced around and pass it off as nothing just as we used to.
Young Persons game and we are still trying to play!!
Edited by DMiller - 03 Jul 2021 at 8:37am
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 4:58am
The biggest pain comes from reaching your ass pocket for your wallet.............
HD3
ghostriderinthesky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ghostriderinthesky Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2021 at 4:04pm
i'll bet your undercarriage is worn out and the sproket is bumping the pins.  the final drive will go out about the same time your back goes out.
Carthus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carthus Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2021 at 2:30am
I tried all the possible remedies found on the internet. Massage chair, pillowless sleeping, specialized toys for the back, and after I went to the doctor. He told me that he could do some procedures for me, but it is best to do a few 대전 출장 안마 sessions. Thought a lot until I decided because I couldn't believe that massage could treat some problems I had accumulated for years! But I want to tell: u it's a miracle! Now I can't imagine how I lived with those pains. My back has returned to normal, and I can even work day and night. I supported 100%.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2021 at 5:07am
SPAM REPORTED!
This page was generated in 0.193 seconds.
