Silent 620 |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7254 |
Posted: 26 Jun 2010 at 11:01pm |
Question for the 620/720 experts here. I've had it apart for the last few weeks getting the gas tank cleaned, new fuel filter, and cleaned and adjusted the carb. I put everything back together, now I can't get a sound from the starter. All lights work, and the battery has plenty of juice. Is there a blown fuse somewhere? Will the engine have to come out to access the starter (God, I hope not!). It started great before I took the fuel system apart.
I would appreciate any help! Thanks!
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10579 |
Have you checked the safety switches? HTH Tracy Martin
Larry Miller
Orange Level Joined: 21 Nov 2009 Location: NWIL Points: 896 |
I know you have to pull the engine to get to the starter, and then it is behind the cowling. I had mine out three or four times before I found the bad winding in the starter. It ran on the bench but not under any load.
Check the ground connections first.
I used to be young and stupid, now I am not young anymore.
DSeries4
Tracy, Where are the safety switches on it? I am not that familiar with it yet...
Tracy Martin TN
I think one on clutch pedal, or actuated by pedal, could be at tranny. I know there is one on hydro levers, must be in neutral to start.Pretty sure all pto clutches must be off also.HTH Tracy Martin
norm [ind]
Orange Level Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
by pass all switches go directly to staRTer with a jumper if starter workks problem then is safety switches will help solve your problems and elimate a lot of work ten look for problem 40+ yrs. under my belt
norm [ind]
DSeries4
Problem solved - clean the connections on the ignition switch!
DREAM
Orange Level Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Glad you got that D series. I was gonna join in. Have worked on a few of the Simplicity models of those. Glad you didn't have to get the starter off. Engine does have to come out. I would recommend replacing/rebuilding anything else you thought might EVER wear out in that area while you had it out.LOL! It's not as bad as working on some Toros, but it still sucks!
