lowered D-14 |
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24874 |
Topic: lowered D-14Posted: 06 Nov 2016 at 4:00pm |
OK, just curious, has anyone 'lowered' a D-14 before? If so is it as 'easy' as rotating/swapping the rear axle pieces and doing the same up front?
Thinking of a wnter project as I really don't need 4 D-14s here... Jay |
Joined: 11 Sep 2009 Location: illinois Points: 89138 |
Posted: 06 Nov 2016 at 7:17pm |
I have never seen one... I suppose the finals bolt on with 4 -6 bolts just like the B and CA ?? Should work OK.. How much drop do you get when you rotate ( center line of bull shaft to axle shaft) ? You might have to make a new front axle, or cut off the ends and reweld to the original cross arm.
Posted: 06 Nov 2016 at 7:59pm |
Looks lik eI could get 8" drop on the front just by swapping left for right and turning hte stub axles upside down ! Flipping the rears I'd get about 10" drop.
The current plan is to get tractor running 100% ,then see about the 'lowering'. Everything is heavy..sigh, back ain't up to it quite yet. It was h-e- double- toothpick just swapping 4 tires past 2 days..... the mind is strong, the back not so much..... Jay |
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 06 Nov 2016 at 8:45pm |
Flipping the rears I think would give you closer to 20" of drop, not just 10" because changing from 10" down, to 10" up, drops the housing 20" I don't think there is that much clearance under the rear housing without the hitch parts. Maybe, but it would be close.
Still in use:
