f2 cylinder clearance |
JFREED
Joined: 11 Sep 2011 Location: SOUTH MICHIGAN Points: 113 |
Topic: f2 cylinder clearancePosted: 29 Oct 2016 at 9:46pm |
We have 2 concaves in our machine,one on the door and one in the #3 spot. Setting up for beans I used a 3/8 in bar stock between cylinder and #3 concave. After the door was closed and seperator was started,cylinder hit hard on door concave. What is the proper way to set clearance with #2 concave omitted?
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3544 |
Posted: 29 Oct 2016 at 10:22pm |
hmmm you have a problem... the clearance between the cylinder bars and ALL the concaves are supposed to be the same...
the door concave should be the same as the third..
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8729 |
Posted: 29 Oct 2016 at 10:56pm |
agree with Tim....Double check your work.Look to see door isn't caved in raising bar....something is out of whack somewhere
I always check the most fwd concave on the rear door,no matter which position it's in...it's easiest. Edited by SteveM C/IL - 29 Oct 2016 at 10:58pm |
MACK
Posted: 30 Oct 2016 at 6:59am |
Are you sure the rear swing down door is bolted up tight? Remove cylinder belt, turn cylinder and look for a cylinder bar that is higher than others or loose. MACK
JFREED
Posted: 30 Oct 2016 at 7:22am |
Mac might be on to something. Last time we had it down it was a bear to get closed. Thanx
Posted: 30 Oct 2016 at 9:43am |
Back in the day, I used to lay an 1/8" thick strap under the #5 concave to create a wedge effect like the L and M series had. Remove the cylinder belt and lower the cylinder while spinning it until it would start to tick both sides, and then zero the gauges.
Dmpaul89
Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Posted: 30 Oct 2016 at 3:22pm |
Remove the header so you can see the door concave while its closed
JFREED
Posted: 30 Oct 2016 at 7:38pm |
Dmpaul, i am trying to visualize if it`s possible to see under/around feeder beater to see that concave
Dmpaul89
Posted: 30 Oct 2016 at 7:57pm |
When I last leveled my F cylinder I had the head off anyway switching heads and I used the door concave to check my clearance. you get a little view under the beater and enough room to get a hand in to measure. the F2 id imagine
should be the same
JFREED
Posted: 30 Oct 2016 at 8:18pm |
Thank for the advice Dm. Have 18 acres of beans to run if it ever dries out. Then bean head comes off for storage. Will definitly take a peek then
