720 Hour Meter |
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2163 |
Topic: 720 Hour MeterPosted: 16 Oct 2016 at 6:10pm |
While I'm on a roll with my questions on the 720, I've noticed that my hour meter is not functioning. Is there an easy fix, or do I need to replace the meter? some wiring? connections? Dave
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Posted: 16 Oct 2016 at 8:32pm |
needs 12v. when the key is on and a good ground if that doesnt work then its bad
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7630 |
Posted: 16 Oct 2016 at 9:36pm |
most likely the meter is no good. I've come across many that do not work, mine included.
mnoonan-NEWI
Joined: 11 Sep 2009 Location: Marinette, WI Points: 739 |
Posted: 16 Oct 2016 at 10:04pm |
Check out this replacement hour meter;
Edited by mnoonan-NEWI - 16 Oct 2016 at 10:07pm |
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1888 |
Posted: 17 Oct 2016 at 7:32am |
you can buy hobbs meters off ebay and amazon. easiest way to install is pull the steering wheel, unbolt the dash and left to gain access.
Dave (NE)
Posted: 23 Oct 2016 at 8:45am |
I got the meter from surplus center and got it installed. I does work, so I'm pleased with that. Thanks for all the help. Dave
Herb(GA)
Joined: 15 Sep 2009 Location: United States Points: 1039 |
Posted: 26 Oct 2016 at 12:25pm |
Dave; You bought Item # 1-2507, how did you do the rectangular installation? Herb(GA)
Dave (NE)
Posted: 26 Oct 2016 at 12:42pm |
Herb, I had to take the dash loose, remove steering wheel, lifted it up so I could work under it without completely disconnecting everything (throttle cable, choke cable, etc.) and removed the old one. Slipped the new one in, put the bolts provided in, connected the wires and was done. I admit, it was kind of a pain. Hope that adequately explains what I did. Let me know if you need more info. Dave |
