Allis Bolt Part Numbers
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Topic: Allis Bolt Part Numbers
    Posted: 02 Oct 2016 at 4:58pm
In my Allis G Parts Manual, all the bolts are identified by part number. Is there any cross reference from bolt part number to bolt size?
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2016 at 5:37pm
I bought an Allis-Chalmers "Dealer Parts Catalog and Numerical Index for Standard Parts" a few years ago on e-bay. It is an interesting book which has pictures and descriptions of all sorts of standard hardware used on A-C machines with the corresponding A-C part numbers. Examples: bolts, nuts, washers, rivets, keys,, setscrews, pipe fittings, hose fittings and tubing fittings. If you can give me the part number of your bolt, I should be able to give you it's standard description.
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 5:47am
Thanks for the info. I wouldn't want to trouble you every time I needed a bolt size. With the information you have provided, I have found a copy of the parts catalog you mentioned
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2016 at 10:15am
That's great!
