200 hydraulic problem?
JohnCT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCT Quote  Post ReplyReply Direct Link To This Post Topic: 200 hydraulic problem?
    Posted: 19 Jun 2010 at 7:48pm
Hi, I'm having a problem with my 73 Allis 200. Today I noticed I have to rev up the motor to make it move as if the hydraulics aren't working at lower rpms.  I checked the hydraulic level, and its OK.  Its not the clutch slipping. With the power director in hi and transmission in gear, it wouldnt move till I raised rpms. It started doing this after two hours of baling so it was good and hot. Any suggestions? Thanks, John
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 7:59pm
Does the pto work properly? If it does, you need to check the hyraulic pressure under right foot floor board. I had same problem with 185. Poor pressure between powerdirector valve and power director. I took pd apart and still nothing. Found a new one on ebay and installed with good results. Have no idea why it quite working. Bill
