WC Seat parts
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Topic: WC Seat parts
    Posted: 18 Jun 2010 at 8:05am
My 37 unstyled WC has what I think in a Monroe Easy Ride Seat.  I can't seem to find it in the Agco parts under WC, WD, CA or anything else.  It has a shock absorber up the back of the seat, a coil spring directly under the seat but my problem in the pivot.  Steiners show a center piece threaded on both ends with 2 bolts holding it to the framework.  Granted, mine is over 70 years old and probably been jurymandered as it has one 3/8" through bolt.  Any ideas as to where to find the Agco parts section on these seats?  Once again I'm probably missing the obvious!
Andrew Kimbrough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Kimbrough Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 8:22am
JW can you post a pic of your seat?  I think I have the same seat on a parts unstyled WC that I have.  If so I could take a look and see if that part is good that you're needing.  I am in Indiana but i'm sure shipping wouldn't be that much.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 8:59am
You will not find the parts breakdown for a Monroe seat in any Allis Chalmers parts book they were made by Monroe.
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 7:22pm
Here is the parts diagram for the Monroe 16009 WC seat:
A-C Weight ID reference and other goodies at brianahart.net
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2010 at 7:31pm
This don't help you much, but is good reading no less:
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 12:28pm
i HAVE SEVERAL OF THE MONROE SEAT UNITS FOR PARTS. mAY HAVE WHAT YOU NEED. 785-353-2392
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2010 at 2:05pm
Thanks, thats exactly what I needed, now I need to see if I can get whatever is in the bracket out.  I have enough of the wrong ordered parts lying around here.
Guests View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2010 at 9:38pm
This page was generated in 0.073 seconds.
