B112 hydro pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: B112 hydro pump
    Posted: 01 Sep 2016 at 2:02pm
OK, so it steers a tad better(added grease) but the hydraulic pump unit is 195*F ! It does work but I'm pretty sure 195 is waaay too hot.
Any idears ?
Jay
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 3:38pm
For the hydrolift?  Any chance it is on pressure?  Not sure how the system is set up, but being on pressure trying to pump is a fast way to heat up the oil.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 4:57pm
Yeah, the lift hydraulic pump/reservoir unit. It's new to me...seems it lifts when the lever is pulled towards me.. I may have been running around the yard(trying to get he steering looser) with it there,oops....
It does make perfect sense what you said !
I keep searching for a 'one point to 3 point adapter' as all I have is a NEW 48" deck and no implements....though I have a lot of Cat 0 Sears/Brinly stuff I want to use....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 6:08pm
Not sure your going to find an adapter. Fabbing one shouldn't be too hard. Maybe even be able to use some other brand parts you can find on eBay. Just bought my first 112 with a hydrolift. Fastenal should call me in a week or so with it ready to pick up. First thing to find is a 48" deck. Have to hang my 42" under it for now.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 6:16am
Aaron
Mine came with a 48" deck, BRAND NEW shell ! maybe used 3-4 times( < 1 season ) as the simplicity red(?) powder coat is just coming off underneath. Needs belts though....
B&S engine says 1969 ( 'code' numbers). Throttle lock till works !
I've yet to see ANY one point to 3point conversions. Lots of 'use sleeve hitch stuff on 3pt' though...wrong way.....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 6:43am
The PTO belt on the tractor is Simp 164146 which is 1/2x34".  The cross drive belt from the PTO to the deck is Simp 108458 which is 1/2x45" and the arbor belt is Simp 165048 which is 1/2x85".  The better the belt the longer they last.  I've blown up a few of the cross drive belts. The cheap ones don't like the half twist.  Have had decent luck with Gate, but if you can find the genuine Simplicity belts, they last the longest.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 12:34pm
thanks, I'll write them down though I'll never use the deck,info is good to have !
Jay
This page was generated in 0.228 seconds.
