B112
OrangeYaHappy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeYaHappy Quote  Post ReplyReply Direct Link To This Post Topic: B112
    Posted: 24 Aug 2016 at 5:35pm
I just picked up a B112, the wiring has had a little too much tlc over the years and it's a mess. I'm wanting to change the harness...is it the same wiring as a B110? Any help would be great.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2016 at 9:38pm
There were two wiring systems used on a B-112 or B-110. One system has a push button start switch and no solenoid (early system). The newer ones had just a regular ignition switch and has a solenoid on the generator bracket. The systems for B-110 and B-112 are interchangeable as long as you are swapping early for early or late with late.
