hd6 dozer clutch
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Topic: hd6 dozer clutch
    Posted: 15 Aug 2016 at 12:45pm
Im looking at a hd 6 dozer with a oil clutch the guy said it wont stop pulling when its in gear I know my dads old 6g wont pull at all if the oil is not flowing found that out a few years back after changing the oil filter . could this be the disk in the clutches being warped
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2016 at 5:59pm
Clutch facing may have separated and stacked, not much clearance in the flywheel to pressure plate and a section of separated disc would keep from disengaging.  Could also be a spline step seize where the disc just cannot get off the flywheel or pressure plate.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2016 at 8:51am
If you have a ROCKFORD wet cluch maybe the small camshaft are bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2016 at 12:58pm
Allis Chalmers HD6-E http://monroe.craigslist.org/hvo/5723953380
