How much boost |
Ronnie ![]() Orange Level ![]() ![]() Joined: 23 Mar 2014 Location: New Brighton Points: 557 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Aug 2016 at 6:28am |
Will a stock 301 out of a 8010 take.
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Dont know about stock, but 8 years ago the McKimm 180 twin turboed "Power Maxx" was leaving the line under 80 lbs of pressure.
AaronSEIA |
bsallis180 ![]() Silver Level ![]() Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
it will take as much as it can till it breaks... maybe 30psi right way put fire rings in the sleeves and forget about it
I'm making 40 pounds.
I think I will open the waste gate and keep her around 25 |
200 allis ![]() Silver Level ![]() ![]() Joined: 11 Mar 2014 Location: new jersey Points: 203 |
I have a 200 makes 60 psi boost and isn't fire ringed and a friend of mine is running a 190 with 80 pounds with out fire rings
200 allis are u runing factory head bolts and torque speck
Stock head bolts over torqued a Lil. Left rocker arm assembly off and torque with all short bolts. Then put rocker arm assembly back on and torque it down. Plugged block heater in over night and retorqued.
O.P.S. Heads ![]() Orange Level Access ![]() Joined: 02 Jan 2013 Location: Iowa Points: 574 |
The boost is a factor but not the only factor. How much power you develop is a much bigger deal. You can make 200 HP with 60 lbs. of boost or you can make 800 HP with 50 lbs. All depends on the setup. I would be certain that your connecting rods are hardened first. the softer OEM rods will bend before the head gasket blows if they are not heat treated.
I think a better way to describe performance is to give the weight of the tractor and in what gear you can spin it out - finish the run in. That is a more accurate way to describe how good the engine is and the stress that is applied to it. Edited by O.P.S. Heads - 04 Aug 2016 at 8:45pm |
200 allis do u have hardens rods in ur engine and what weight class do u run.
My rods are hardened but the 7000 series rods were harder then 3# series. I have been running 7500 and 8500
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21915 |
On the 426 small pin rods, if they said JAPAN on them, there were better than newer generation rods.
I think I will just back my boost down some so i dont break any thing.
So what would it cost to get rods hardend |
Max Simpson did my rods but don't think he is doing it any more. What timing u running makes big difference.
Just under stock timing for this moment
