how to cut tires?
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: how to cut tires?
    Posted: 12 Jun 2010 at 10:36am
I have a chance to buy a used set of 15.5x38 tires cheap. They both still have a fair amout of tread, enough to pull with. Problem is one is a little newer and has more tread. I would like to cut it down to match the other. What is the easiest way to do this? Our rules wont allow "cut" tires, how do I make it look uncut? Thanks for any ideas, JM
ChuckLuedtkeSEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 1:58pm
someone gave me this idea and it worked well.  I put my tractor in reverse gear on some concrete and spun the tires backwards.  I used a chain hooked to my big work truck so it wouldn't move on me.  I would then hold the brake on the opposite side that I was trying to "cut" and the concrete would wear a nice edge on each lug.  This would work for you and it would not necessarily be a cut tire as it was road worn into shape.   Good luck.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 3:21pm
Man, I like that idea! you're right, the concrete would produce a "wear" pattern that would appear worked, not cut
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 6:06pm
A new way to spin balance as well! Sorta!
What about the rubber build-up on the concrete?
Dave in PA
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 6:15pm
Dave in PA
blame it on the teenagers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 6:23pm
Lou, I am thinking that we all were teenagers as well, can't remember back that far, BUT
YOU NEVER DID THAT!  LOL  we all did!  You can blame me, you, and all of us on that one!
Dave in PA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 7:29pm
I have been told you can buy a wheel to put on your 4in or 4 1/2 inch angle grinder to cut tires down. It is a messy job and you wouldn't be able to grind the leading edge but you could use that tool and then finish up on the barnyard cement in reverse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 7:41pm
Find a stretch of concrete road that isn't well traveled (or a NEW road) and drag the tractor with a 4X4 truck about 2 to 5 mph while spinning the wheels backwards.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 8:30pm
wet the surface with water while you're turning the tire backwards..
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 9:13pm
neat idea DR Allis! can I do that with my 210? might take a big truck! LOL!
