|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 190 lift arm seals |
| Post Reply   |
| acplowboy45   Silver Level     Joined: 09 May 2013 Location: connersville IN Points: 264 |  Post Options  Thanks(0)  Quote  Reply  Topic: 190 lift arm seals Posted: 24 Jun 2016 at 12:10pm |
   I have a 190 and I'm replacing the seals in the lift arms. I have removed the lift arms. Kinda at stand still where do I go from here do I need to replace the plate the has the top link on it. Any help would be great.
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 24 Jun 2016 at 12:16pm |
   Slide the shaft sideways as far as it will go and change one seal.....slide it back the other way and change the second seal. Use lots of grease. If they still leak, you need new bushings to support the shaft.
| acplowboy45   Silver Level     Joined: 09 May 2013 Location: connersville IN Points: 264 |  Post Options  Thanks(0)  Quote  Reply  Posted: 24 Jun 2016 at 12:30pm |
   Do I need to remove the top link plate that has the 4 bolts.so slide that splined shaft from one side to another to get seals out.
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 24 Jun 2016 at 12:36pm |
   NO !!!
| DSeries4   Orange Level     Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7533 |  Post Options  Thanks(0)  Quote  Reply  Posted: 24 Jun 2016 at 9:46pm |
   Replace the bushings while you are at it.  They are most likely worn.  The top link mounting has nothing to do with this job.
     '49 G, '54 WD45, '55 CA, '56 WD45D, '57 WD45, '58 D14, '59 D14, '60 D14, '63 D15D, '66 D15II, '66 D21II, '67 D17IV, '67 D17IVD, '67 190XTD, '73 620, '76 185,  '77 175, '84 8030, '85 6080
| acplowboy45   Silver Level     Joined: 09 May 2013 Location: connersville IN Points: 264 |  Post Options  Thanks(0)  Quote  Reply  Posted: 25 Jun 2016 at 8:21am |
   Well I got everything tore into and found out all I have is o-rings in the back not seals. Anything I should be aware of when I put these back in.
| DSeries4   Orange Level     Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7533 |  Post Options  Thanks(0)  Quote  Reply  Posted: 25 Jun 2016 at 8:34am |
   The O rings ARE the seals.  Replacing the bushings will be the hard part, the O rings are no problem (just oil them up well).
| Play Farmer   Orange Level   Joined: 13 Jan 2016 Location: NNY Points: 732 |  Post Options  Thanks(0)  Quote  Reply  Posted: 25 Jun 2016 at 1:15pm |
   The o-rings can be the seal but there may also be a back-up ring.
| acplowboy45   Silver Level     Joined: 09 May 2013 Location: connersville IN Points: 264 |  Post Options  Thanks(0)  Quote  Reply  Posted: 26 Jun 2016 at 10:33pm |
   What are felt like looking o-rings for.
| Play Farmer   Orange Level   Joined: 13 Jan 2016 Location: NNY Points: 732 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 5:21am |
   Without looking at it I'd say maybe a wiper. Do you have a manual? If not I'd suggest getting one. | |
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 9:10am |
   The original back-up rings may have been made of different material than the new ones. Back-up rings to the outside and Orings to the inside...lots of oil or grease to avoid cutting them.
| acplowboy45   Silver Level     Joined: 09 May 2013 Location: connersville IN Points: 264 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 1:46pm |
   Big ? I just went to agco bought the seals i needed it's green colored do I still need the rubber o-rings too....the agco diagram just shows a seal no o-rings..and which way does the seal go in the flat side of seal to the inside of outside of the tractor
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 2:07pm |
   Maybe they have changed the actual design of the part. The AGCO parts man should be able to tell you.
| acplowboy45   Silver Level     Joined: 09 May 2013 Location: connersville IN Points: 264 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 2:28pm |
   So I call agco part basically no nothing I did find out there two different parts I guess u could say...one was a counter boar or and internal groove....mine has an internal groove..my 190 was one of the first ones built with serial# 1003..that's all I know  | |
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 2:33pm |
   That drive in style seal didn't start until a model 200 tractor.
| acplowboy45   Silver Level     Joined: 09 May 2013 Location: connersville IN Points: 264 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 2:53pm |
   All I know is that I took a screwdriver and fliped the oring out of a groove in the housing
| acplowboy45   Silver Level     Joined: 09 May 2013 Location: connersville IN Points: 264 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 4:35pm |
   Are the lift arm piece have a certain way they are suppose to go on cause there a really pain in the butt and how do u get both arms on the same.
| DrAllis   Orange Level Access   Joined: 12 Sep 2009 Points: 22140 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 4:44pm |
   The arms need to be timed to each other. They are not timed to the shaft. All the shaft splines are equal distance from each other. Welcome to the world of tractor wrenching.......some days are better than others.
| Lynn Marshall   Orange Level Access     Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2425 |  Post Options  Thanks(0)  Quote  Reply  Posted: 27 Jun 2016 at 9:16pm |
   I've never seen a 190 that used anything but an O-ring,no back up ring or seal.  Seals were later 200's.
| acplowboy45   Silver Level     Joined: 09 May 2013 Location: connersville IN Points: 264 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Jun 2016 at 8:25am |
   I have no clue myself I put the seal in it and it went in just fine..I guess I will see what happens when I use it. My Tractor must be a component Tractor ranging from 190-200 because everyone said a 190 has just the PTO under the seat...mine has the under the seat PTO along with the lever on the side of the console...neutral brake and then engage..either this tractor has had some serious up grades thur it's life..
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
