D17 Lift arm problem
alan1959 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Lift arm problem
    Posted: 30 May 2016 at 4:21pm
I have recently gotten a D17 I believe a series IV and the lift arms will lift a mower and a 9' rear blade but will not lift my plow. The arms do drift down very slowly. I am thinking the internal lift cylinder packing/seals and or the hose going to the cylinder. Did the hose and cylinder when I was a kid on our D15 series II with my dad. Don't remember a whole lot about it. Is it a horrible job to do if that is the problem? Any help would be greatly appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 4:36pm
I thought the lift cylinders on a Series 4 were on the outside.  Are the hydraulic controls on the right hand side of the tractor or behind the steering wheel?  If behind, then it is not a series 4.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
housemover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote housemover Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 4:56pm
Series IV D-17 Hyd cylinders (plural there was one on each side) were on the outside!
Post Options Post Options   Thanks (0) Thanks(0)   Quote housemover Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 5:01pm
Forgot to ask in the other post where's the traction booster lever located during all of this (up, down, or in the middle)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 5:19pm
OK, from the descriptions this must be a series III. The lift lever is under the traction booster lever which is in the lowest position. There is a control valve/lever on left rear by the remotes.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 8:00pm
Sounds like what mine was doing, before it quit entirety. As you mentioned, mine need both a new internal hose and the elbow was cracked.
It's an easy job too. Took maybe 2-3 hours, and that was going slow taking my time as I had never been in one.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 10:25pm
If it is hose or cylinder, rear end dip stick will be showing over full. Sounds more like a weak pump .    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 7:32pm
Tried using remote hydraulic connection on 10' transport discs. It lifted them no problem. And they stay up no drift. So I don't think pump is the problem. Yet the lift arms when raised do drift down. Really leaning on the lift arm cylinder and or hose. Any more thoughts? I really appreciate any responses!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 7:40pm
You say there is "a control valve/lever on the left rear by the remotes". Remotes to me means more than one coupler, and a D-17 of that age only has one coupler, not two. So, I think you have an operational problem, a two-way valve and/or the previous owner has it plumbed up wrong. If you aren't losing hydraulic fluid and gaining transmission oil, there isn't a problem with a hose or seals internally !!! A picture would be very helpful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 6:20pm
The control valve lever I mentioned in an earlier post is the transport valve. Sorry our D15 didn't have one. I am learning! Hooked into the other quick disconnect and tried lifting discs (10' transport) and it works great. Just the lift arms wont lift the plow up more than a couple inches. I am thinking still the pump is fine or it wouldn't lift the discs. Maybe I am wrong. Will post a couple pics tomorrow.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 10:53pm
A transport valve does not have a lever on it. It only has a knob.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 7:34am
"I hooked into the other quick disconnect and tried lifting 10 ft discs and it worked great". There is only ONE quick disconnect(coupler) on a D-17, unless there has been another valve added. DOES YOUR DISC HYDRAULIC CYLINDER HAVE TWO HOSES OR ONE HOSE????????????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 4:49pm
1 hose. Sorry, this tractor different than the D15 we have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 4:50pm
There are 2 disconnects on a valve with lever. To the right is a single disconnect. I think someone put the second one on the left, not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 4:54pm
Now, that we have established there actually is an "added-on two-way valve" (non-factory), how do you make your lift arms raise??????? Are you activating this lever on the added-on valve and then the arms lift up??
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan1959 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 6:44pm
Problem Solved!!!! The hose was hooked to the disconnect on the right. So I unplugged it and just plugged in to the middle disconnect, just to keep it clean and it works perfect! Thanks so much to everyone for their time and effort!!
This page was generated in 0.225 seconds.
