175 power director question
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Topic: 175 power director question
    Posted: 23 May 2016 at 9:55am
Yesterday the power director started getting harder to put into high and snaps hard now as it comes out. It has been trying to creep in neutral for a while now and I just changed the oil a month ago. Any ideas or does this sound normal cause the old oil had been there a while and had a little sludge in it
If fishing is a sport your looking at an athlete
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 6:07pm
Just tried taking off with the power director in neutral and pushed it into second and it started grinding so guessing it's going to have to be replaced. I can put it in gear and take off with the foot clutch fine so may keep running it to try and get spraying done
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 6:57pm
Why do you think you have something wrong??? The Power Director clutch should NEVER be used to shift the transmission from neutral into any gear. All Power Director clutches tend to "creep" somewhat in neutral, and the colder the hydraulic oil, the more it will want to creep when placed in the neutral position. You need to worry about the hand lever staying in high or low without having to hold it there and whether or not it slips under load. How long have you owned this tractor??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 10:24pm
Its been on the farm since the mid 70s. Maybe I didnt explain it well it does hold itself in high or low but when the transmission is in the 1st or 2nd gear position and the power director is in neutral when I push the lever forward to take off from a stop, which would be second gear, the the power director lever starts to make a grinding noise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 7:21am
Now, we're getting somewhere. If this noise only occurs when in 1st or 2nd speeds (which is LOW gear in the transmission), the problem is in the transmission, not the Power Director clutch. I'd suspect maybe a bad rear countershaft bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 9:41am
Ok I'll see what it does in all the gears tonight when I get home
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 5:15pm
Ok just tried it out and it seems to be making the noise in any of the gears going into high range but seems fine and normal goin into low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 7:02pm
You may have broken drive discs in high range. This "noise" started after changing the hydraulic oil?? or it was doing it before you changed the oil??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 6:13am
Didn't notice it until maybe 10-15 hrs after changing it. It seems quiet all the way in gear just makes the noise as your putting it in high range. My uncle sprayed all day with it just using the foot clutch and everything seemed fine as long as you don't use the power director for starting movement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 6:24am
What brand/type of oil did you use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2016 at 6:58am
Yellow bucket from rural king
