D-15 vs D-14 crankshaft
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: D-15 vs D-14 crankshaft
    Posted: 04 Jun 2010 at 1:58pm
I have a D-14 that I am working on and getting ready to overhaul. I was curious if a crank from a D-15 series I will interchange?? How about a d-15 series II?
Thanks!
Ben
ORANGE FARM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ORANGE FARM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 2:25pm
D15 SER I AND D15 SER II ARE THE SAME. THE BIG DIFFERENTS IS THE RODS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 3:25pm
According to tractordata.com the stroke is the same in all 3 tractors with the series II D15 having a bigger bore than the 14 or 15 series I. They also show a difference in compression ratio between the 14 and series I 15. I wonder if you can't replace the internals in a 14 to make it a 160 cu in like the series II 15.
Edited by CTuckerNWIL - 04 Jun 2010 at 3:32pm
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 5:47pm
The crankshaft from a D14 and D15 series I are the same.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 6:13pm
You can bore and stroke them . Jamie could probably tell you everything that can be done .
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 7:47pm
  crankshafts are the same on d-14-15   sleeves are different  160 orings are in block
   d-14 orings are on sleeves  different iin cu  in
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 9:26pm
The D-14 O rings are in the block also.
I just installed a set.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 10:47pm
So, I can install the crank from a D-15 into my D-14. They are identical right? The D-14, D-15 series I and II both have the same stroke right?
Thanks!
Ben
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 10:52pm
Ok just looked at the tractor data.com site. Lots of good stuff there!!!
