Fork lift Won't start |
Rod
Guest Group
Topic: Fork lift Won't startPosted: 06 Apr 2018 at 10:08am |
Hi, We have an Allis Chalmers Moderl No: Acc40C PS Type G
It was running good for years of normal use, one day It just didn't start!!! I checked all ignition system and found no problems on it, the propane seems to be the issue to work on, but not sure if the gas valve is blocking the gas or something else. At this point, it's been a few days of trying to fix the problem with no success! If some one can help me with this problem, It will be appreciated and any suggestion on what can I check next, please let me know...
WDman1949
Posted: 06 Apr 2018 at 4:32pm |
Rod check your PM as I sent some help
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55261 |
Posted: 06 Apr 2018 at 6:53pm |
When they sit, the hole spiders plug up the propane regulator valve...
