Fordson Crawler
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Topic: Fordson Crawler
    Posted: 18 Jul 2015 at 3:55pm
Started to work on this project and have had it on my trailer seems like forever.
Today we unloaded the Crawler with the 4020 and 1066 as it did not roll.
Removed all the brackets that used to support a blade.
Only one of the bottom roller moved.
We got all the other rollers free up, there is a tube that supplies oil to them.
We used diesel and some oil and work each one got all of them to turn.
Then we cleaned up the bottom tracks the best I could with air and put some of the diesel/oil on the pin area's.
Tap on the tracks with hammer to help get some movement.
Then hook up the 4020 and the 2010 loader tractor on the front and back side.
We took are time and moved each way.
More hitting with the Sledge.
Finally it moved all the around.
Also pick up this 1925 tractor to use as the motor is junk and gas tank and other parts are bad on the crawler.
Edited by Richardmo - 18 Jul 2015 at 9:48pm
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2015 at 5:07pm
Wow, that will be quite a project but worth it when finished.  Don't see a crawler on every street corner!
Allis Express participant
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2015 at 2:23pm
Traxon conversion
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2015 at 10:04pm
that is one funky lookin drive and track system on that thing! gosh...you'd gits a lot of exercise gittin up on them 2 tractors each time!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2015 at 10:14pm
Now those are some TALL tractors! We don't have those down here!
